Quick question
Old Dec 29, 2001 | 10:06 PM
Quick question
I'm very close to buying a 7, but wanted to know something. It has 65k miles on it, and had a $6k rebuild at 60k. I'm getting the compression test, but it seems to me with a rebuild like that, this car is in pretty good shape. How hard would it have to have been driven since the rebuild for me to have to worry about a blow? Thank you.
Old Dec 30, 2001 | 12:31 AM
Brent Dalton's Avatar
Sua Sponte
not very hard at all. The rotary is very expendable, no matter how much money is put into it. If it is not properly warmed up and cooled down everytime, or if it is ever overheated, or if it ever ran lean....then it could be shot before you can blink. Def. get the compression test done. Also, look in the oil filler neck and see if there is any white stuff in there, if there is, chances are you have a coolant seal bad, move on to the next car. Those are the 2 main things to look for. I'm by far no rotary expert, but I just went through the buying process about a month ago and just trying to pass along a few pointers. Oh yeah, one last thing, make sure you shift into all the gears...alot of times 5th will grind due to "missed" second to third shifts. If this be the case, I'd advise finding another one also. Hope this helps. Later.
Memphis
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
