Power FC How Much Hp Should I Get
Old Dec 29, 2001 | 06:56 PM
Question How Much Hp Should I Get
JUST OUT OF CURIOSITY,
ROUGHLY, HOW MUCH HP SHOULD I BE SEEING WITH AN
APEXI PFC AT STOCK BOOST, WITH INTAKE, DP, MP, & CB ON
A 93 R1 TT? REARWHEEL AND FLYWHEEL + WHAT IS THE USUAL
PERCENTAGE DROP FROM FLYWHEEL TO REARWHEELS? I APPRECIATE
ANY INFO ON THIS, THANKS.
Old Dec 29, 2001 | 07:43 PM
JoeD's Avatar
im guessin 270 RWHP and 310 flywheel hp.
Old Dec 30, 2001 | 12:03 AM
skotx's Avatar
Registered Abuser
The numbers I always hear for a stock car are 255 flywheel, 218 rear wheel. So that's a drop of about 15.5%. Keep in mind that stock boost in a PFC is not the same as stock boost in a stock FD. A stock FD is set at 10 PSI, whereas if you didn't mess with the boost settings in your PFC you're running at 0.8 kg/cm^2, which is 11.38 PSI.
Old Dec 30, 2001 | 04:27 PM
Lightbulb CHANGE BOOST?
PFC CAN ADJUST BOOST WITHOUT ADDITIONAL BOOST CONTROLLERS???
OR COMES WITH THEM AS WELL? THANKS FOR THE INFO SO FAR.
VERY HELPFUL?
Old Jan 1, 2002 | 08:08 AM
You can change boost settings with the FC Commander.
