Post your spark plug photos here
Old Apr 19, 2005 | 07:49 PM
scotty305's Avatar
~17 MPG
If you've taken photos of your spark plugs after removal, please share them here. Here are some of mine to start:
Engine mileage: 50k , no modifications.
BUR7EQP leading, BUR9EQP trailing. These plugs were used for at least 5000 miles:
Engine mileage: 53.5k , minor modifications (DP)
BR8EIX leading, BR9EIX trailing. After 3500 miles:
Engine mileage: 56.7k , minor mods (DP)
BUR7EQ leading, BUR9EQ trailing. After 3200 miles:
-s-
Attached Thumbnails Post your spark plug photos here-removed-2004-09-22.jpg   Post your spark plug photos here-removed-2004-12-15.jpg
Old Apr 19, 2005 | 07:54 PM
RTS3GEN's Avatar
The Man
wow dude, you've got too much time on your hands to document your plug life/performance. I run NGk race 105's and 115s at the track. Use a spark plug cleaner and some brake cleaner about every 1500miles. mine end up lookinng like the first thumbnail of the irridiums!
Art
Old Apr 19, 2005 | 07:58 PM
Kento's Avatar
2/4 wheel cornering fiend
Boy, that's some serious rounding of the electrode edges after only 3200 miles in the bottom photo...
Old Apr 19, 2005 | 08:44 PM
dis1's Avatar
www.silverbulletrx7.com
Art
If you think he has too much time on his hands you should take a look at my website. I've been documenting my plug life for years. I have plenty of pictures.
Old Apr 19, 2005 | 08:45 PM
scotty305's Avatar
~17 MPG
Yes it is. Here's a photo of the same plugs, before they were installed:
I replaced them with another set of the NGK Iridiums, because of the way the electrodes held up.
I've had them in for 4k miles so far, and the idle is fine. I think I'll keep them for at least 5k. I'd like to try the new RX-8 plugs, but not at $20 per plug.
Attached Thumbnails Post your spark plug photos here-br7eix_bur7eq_comparison.jpg   Post your spark plug photos here-br9eix_3500_miles.jpg
Old Apr 19, 2005 | 10:08 PM
POS7's Avatar
Wankel Shmankel
What are feelings regarding the stock vs nonstock plugs?
I always thought it was "recommended" to use plat BUR7EQ leading, BUR9EQ trailing or 9s all around.
Are the br9eix the so-called racing plugs?
Old Apr 20, 2005 | 08:13 AM
gcthree's Avatar
The iridiums, although expensive, are the way to go. Smooths-out the idle, always run clean.
Old Apr 20, 2005 | 09:50 AM
JTurtonRX_7's Avatar
EFR IWG 8374
These were in for some where from 7-8k miles.
Front Trailing - Front Leading - Rear Leading - Rear Trailing
Old Apr 20, 2005 | 01:34 PM
SNracing's Avatar
aka KingDrunk
how often do you guys change your plugs?
Old Apr 20, 2005 | 01:42 PM
scotty305's Avatar
~17 MPG
dis1 , your site is what inspired me to do this. A forum thread is easier to update.
JTurtonRX_7, how was your idle? Did you notice any change in mileage or performance?
-s-
Old Apr 20, 2005 | 02:09 PM
EFR IWG 8374
Ive been doing a ton of stuff to get the idle right so I have no base line for determining if plugs changed anything.
I change my plugs every other oil change, those I posted went like 3 oil changes Oops.
Can anyone tell me anything by how my plugs look?
Old Apr 20, 2005 | 02:42 PM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
heh, dont have any pics, but mine dont even get a chance to get any build up on them...my new motor has 3500 miles on it and I lost count efter 10 sets.
Old Apr 20, 2005 | 02:56 PM
cblake3's Avatar
I second what this guy said. Is it OK to use Iridiums as opposed to the stock BUR7EQ/BUR9EQ?
Anyone have any bad experience using no-stock plugs? I am concerned because of the difference in design. The Iridiums look like conventional plugs, not the kind I have been using in my 7 since day 1.
Old Apr 20, 2005 | 03:31 PM
scotty305's Avatar
~17 MPG
I've heard that the 'flat-face' design of stock plugs was to prevent against flooding in the FC. If that was their primary purpose, then it's redundant and unnecessary. My car has had the "regular-style" plugs for thousands of miles, hot-starts, cold-starts, and hasn't given me any trouble at all.
The BR*EIX electrode obviously holds up better than the BUR*EQ one, whether that's due to the difference in electrode design or material, the end result is that you will have less misfiring as the plugs age. The RX-8 uses a different plug design, it is closer to the BR*EIX plugs than to the OEM 86-95 BUR*EQ plugs. RX-8 plug info here: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/use-rx-8-iridium-plugs-fd-391496/
NOTE: the BR*EIX plugs are not designed for a rotary, so you will need not be able to install them without a thin-walled socket. I don't think this has been mentioned yet. You can buy one (from most rotary tuners who fabricate things, such as http://www.mazdatrix.com/toolmisc.htm ), or grind your own.
-s-
Old Apr 21, 2005 | 10:27 AM
Scrub's Avatar
bow leggin'
What happened to the last 2 pages of the Rx-8 plug discussion?
Old Apr 21, 2005 | 10:45 AM
tookwik's Avatar
VIP - Very Irish Person
I don't remember which one is which here but one is trailing and one was leading. They were the stock plugs and had been ran for atleast 15k miles. They were on the car when i bought it. One of them was so old that the rod in the middle slid out!
BTW - tell me if the pics don't work
Old Apr 21, 2005 | 03:42 PM
WaLieN's Avatar
Call me gramps!
They don't work.
Old Sep 13, 2005 | 03:17 PM
scotty305's Avatar
~17 MPG
I've been using Autolite plugs for the past 1300 miles or so, here are some photos. The equivalent NGK heat ranges should be 8 leading and 10 trailing. These plugs might be a little too cold for a stock motor, but the car idles fine.
The car had been sitting for about a week, and the front leading plug was wet with fuel. Can anyone tell me what would cause this? Leaky injector?
The electrodes seem to be wearing pretty quickly; an iridium electrode would be nice. I reinstalled these plugs, and am hoping to keep them for another 1000 miles or until the idle quality declines.
-s-
Attached Thumbnails Post your spark plug photos here-autolites_1300_miles_2005-08-19.jpg   Post your spark plug photos here-electrodes_1300_miles_2005-08-19.jpg
Old Sep 27, 2006 | 05:03 PM
ghost-rider's Avatar
To bring the thread back from the dead...
Can spark plugs cause the car to backfire almost like a gun shot and then stall the car?
How do people insert pictures here?
Old Feb 12, 2007 | 11:54 AM
goz's Avatar
goz
i can only get hold of bur9eqp cant get bur7eqp tryed six or seven different places...can i run two bur9eqp...thanks
Old Feb 12, 2007 | 11:28 PM
st8uphiphop's Avatar
how often do u guys change ur plugs??
Old Oct 14, 2007 | 04:15 PM
OzzManG149's Avatar
Pistons Suck
maye time to get some trailing plugs. These have about 1500 iles on them.
Old Oct 15, 2007 | 11:20 AM
Lawman_AUT's Avatar
Sheriff´s FD
Wow, your plugs looking terrible.
Mine looked like tookwiks plugs, i also had the same plugs, BUT some previous owner installed NGK BUR9EQP in trailing and leading, so no BUR7EQP has been installed.
My car wont start now, there´s a lot of fuel in the chambers. I will change plugs and cables now, lets see if something changes.
My car is stock, only aftermarket BLITZ exhaust.
And yes, how often do you change your plugs???? Every oilchange seems VERY often for me...
mfg
Andi
Old Dec 4, 2011 | 03:46 PM
Metan's Avatar
changing mine today, all bur9eqp and all the same look, after 7200mile
this is from back housing
Old Dec 4, 2011 | 09:07 PM
trainwreck517's Avatar
Rx-hippie
BUR9EQ all the way around. Picture of two the leading, ~900 miles on the plug (most of it track time).
Still running a bit rich (10.8s ~ 11.0s a/f) under boost.
