Sponsored by: CARiD
Wiring diagram
Old Apr 18, 2005 | 05:43 PM
rimarx@'s Avatar
Wiring diagram
Hello, I need the wiring diagram (engine harness) by the RX-7 Turbo 1990.
Where I can find it.
Thanks
Old Apr 18, 2005 | 11:07 PM
RX-Racer's Avatar
Aoohh!!!
Try . . .
Try your local mazda dealer! See if they would let you check out their shop manual. Every dealer should have at least 1 rx7 shop manual.
JP
Old Apr 18, 2005 | 11:32 PM
rimarx@'s Avatar
Lamentably here in Chile the only information of the RX-7. I have it.
I have almost all the workshop manual of RX-7. But not the wiring of the serie 5.
Now only I need the information of the connector FEM 02.
Thanks.
Old Apr 18, 2005 | 11:42 PM
RX-Racer's Avatar
Aoohh!!!
What part of the harness do you need a diagram of?
JP
Old Apr 19, 2005 | 12:33 AM
rimarx@'s Avatar
Thanks for you answer.
I am finishing a swap (RX-7 1986 N/A, Engine and transmission Turbo II 1990)
The engine is JDM, The harness It He has two connectors for the ECU And other one for; Circuit opennig relay, main relay, water temp gauge unit, air by-pass relay, etc. In the work shop manual mazda, It He calls FEM-02 connector emission (EM) Harness.
It He has 20 contacts.
Thanks again
Old Apr 19, 2005 | 12:00 PM
rimarx@'s Avatar
This is the connector FEM-02
Old Apr 19, 2005 | 12:18 PM
rimarx@'s Avatar
Fem-02
Another photo more
Thanks
Old Apr 27, 2005 | 07:02 PM
HAILERS's Avatar
HAILERS
I've never seen a series five wiring diagram online. Your best bet MIGHT be to buy just the wiring diagram from mazdatrix.com. I recognize that FEM-02 as beingt the Front Emissions plug.
Personally I would have just kept the 86 harness and made the wiring adjustments to that harness. But that's just me. You'd still need the 90 wiring harness diagrams to do that though. Good luck.
http://www.mazdatrix.com/m-1.htm
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
windom
Sep 11, 2015 04:48 AM
