Mystery wire to a n00b
Old Apr 17, 2005 | 01:51 PM
ih8rotary's Avatar
Newbie
Yes I searched, and came up nodda.. I have a wire bolted to the firewall under the vin stamp and its lookin obviously like a ground... its black and bolted to the firewall.. still has a long bolt attached to it and we just bought the car like this and dont know where it goes... PLEASE help we are trying to solve the 3800 stumble and sure thats the main problem seeing as we just did a ground kit as per the FAQ walkthrough and didnt work and we keep going through good alternators every 15 minutes
Old Apr 17, 2005 | 01:52 PM
Icemark's Avatar
hooks to the back of the motor
Old Apr 17, 2005 | 04:16 PM
WAYNE88N/A's Avatar
Top of the tranny bellhousing, right side of center, just aft of the rear engine housing, you should see a threaded hole. A 10mm bolt attaches the end of the wire there...
If you have the UIM off and can access the rear rotor housing ground stud (you should see the two terminals bolted down there from the harness on top of the engine), just run a new ground wire from that point to the firewall (you'll be accomplishing the same thing as the original jumper wire, but electrically have a better ground potential for the ECU). If you still have the stumble after this mod, it definetly ISN'T the ground...
Old Apr 17, 2005 | 08:07 PM
ih8rotary's Avatar
Newbie
so just reground with some 8ga. and bolt to the rotor housing.. can anyone throw up a diagram on where to bolt it in? i know absolutely nothing bout RX7's sorry
Old Apr 17, 2005 | 09:13 PM
WAYNE88N/A's Avatar
In that case just route the wire to its OEM spot- at the back of the engine on the tranny...
Old Apr 17, 2005 | 09:47 PM
ih8rotary's Avatar
Newbie
one of the bellhousing bolts?
Old Apr 17, 2005 | 10:32 PM
WAYNE88N/A's Avatar
Read my first post, I gave you the OEM location for S4 NA's...Don't know what yours is. In any case, anywhere back there you can find a spot to bolt her down, do it. Make sure the metal surface is clean, of course...
Old Apr 18, 2005 | 12:15 PM
ih8rotary's Avatar
Newbie
alright thnx Ill try that
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
