aluminum bending if heated??
Old Dec 28, 2001 | 10:08 PM
Rotary93's Avatar
Retired RX7 mechanic
Anyone know if aluminum bends if it is heated with a torch?
The reason I ask is because I have an efinii Ypipe that is slightly hitting the alternator....I need to bend a little indent into it....
Anyone know if the aluminum will bend if heated with a torch?
Old Dec 28, 2001 | 10:31 PM
bajaman's Avatar
Constant threat
Aluminum, like most noe-ferrous metals, is not readily workable by heat.
You can change the temper, but it doesn't do much to alter the workability....some alloys are a little more forgiving, but in general, no you can bend it with heat. Shot peening or other cold forming is the way to go....
Old Dec 28, 2001 | 10:58 PM
Sled Driver's Avatar
The Anti-Prius
Slot the holes
Sounds like you just need to shift it over a bit to clear.
Loosen the two nuts & see how much it rotates. Not enough?
Slot the holes in the upper half with a round file.
Worth a try, but you shouldn't have to do anything. Did you change the alternator belt to a differant length?
Old Dec 29, 2001 | 02:01 AM
GsrSol's Avatar
Z06 powered FD
Keep in mind, if you dent the crossover tube it will restrict air flow. My suggestion would be to drill the holes bigger where the crossover meets the y pipe, that way you could move it around a little (have more play).
20B Forum
Sep 22, 2015 07:39 PM
