ISO front brake tool
Old Apr 17, 2005 | 01:46 AM
What do you guys use to remove the lower bolt that holds the caliper braket to the spindel? (1st gen) You know the one, the one that can't be reached with any regular wrench. Is there an off the shelf tool that I can use to make life easier? (same bolt has to be removed to pull the rotor.
I tried the search feature, but came up empty.
Thanks in advance.
Old Apr 17, 2005 | 05:46 PM
jgrewe's Avatar
GET OFF MY LAWN
There's just four bolts behind the rotor. Take off the rotor and its easy. The rotor is only held on by the big center nut with the cotter pin. Is that what you are asking?
Old Apr 17, 2005 | 07:28 PM
No, I'm talking about the bolt that's at the bottom of the bracket that holds the caliper. It is too small to get a wrench into (because of interference from the steering arm). It can only be reached from the back. Its the bolt that holds the caliper bracket to the spindel.
Frisky Arab
13
Aug 18, 2015 05:30 PM
