Power FC Apexi ECU???
Yes, you can use it without the hand controller. One would need the hand controller to do really basic changes with the PFC. The Datalogit pretty much gives you full control. If someone else has a Datalogit and can program the PFC for your car, you won't need the hand controller. It does supply lots of vital and good info however.
The commander is a great monitoring tool and allows you to make changes or monitor all the car's sensors without having a laptop in the car. It's well worth the $300 or so it costs, even if you do have the Datalogit and a laptop, IMO.
Cheers,its just i can get hold of one on its own for real good money and was thinking to maybe buy the controller at a later date. Not had car long and spent out plenty on a few mods allready, only to find i cant drive the car now coz everyones saying the stock ecu cant handle them. Did'nt want knacker it so have left it parked up. Need to get it running again as want my fix!!
^^ what are your mods?
oops never mind. From this thread: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/way-go-next-413552/
I gather that you have a a gutted cat, catback, DP and intake correct? What you need is a boost controller to keep you below 10 psi. THe stock ecu can haldle quite a bit of boltons as LONG as you stay below 10 psi...
