Rewiring the rear bose system to some stock 6x9s how do I do it?
Old Apr 14, 2005 | 09:38 AM
Xeros's Avatar
I'm sorry wha?
How do I use the rear wires to just wire in some stock 6x9s? I searched and didn't find much at all. I was wondering if I could use the stock Bose amp with the 6x9s somehow? Or shoudl I just bypass it and rewire the 6x9s with new wire?
Old Apr 14, 2005 | 10:09 AM
Mahjik's Avatar
Mr. Links
IIRC, the stock BOSE head unit is not amped. Each BOSE speaker has it's own amp. You can replace the headunit and use the BOSE speakers, but I don't believe you can replace the speakers "only" and use the BOSE headunit (without some other amp source).
Old Apr 14, 2005 | 11:26 AM
Xeros's Avatar
I'm sorry wha?
No no I have an after market head unit. I want to keep the front speakers for now, and use my pioneer unit and 2 6x9s in the back. I was wondering if I could use the stock wiring? I believe there is only one plug for the rear bose system right? there is also a small amp under the middle console and I was wondering what it went to?
Old Apr 14, 2005 | 12:32 PM
Mahjik's Avatar
Mr. Links
Arrow
You have to remember that this is the internet; we don't know exactly what's on your care unless you tell us.
I would not recommend using the stock wiring. If you want to try, you'll need to take a look through this thread:
https://www.rx7club.com/interior-exterior-audio-26/bose-wiring-diagram-25090/
Old Apr 14, 2005 | 03:45 PM
X-JaVeN-X's Avatar
Drive.
just run 2 new wires. By the time you finish reading how to use the stock wiring...you could have finished running the new wire.
