Microtech how to change injector settings on the hand controller?
Old Apr 12, 2005 | 06:18 PM
Sir Rupert Hobo's Avatar
seven-less
so i'm reading the handbook and playin with the handset a little to get the idea of everything. but what i can't find is how to change the injector settings cause i went with bigger injectors(had to)
when i ordered my microtech, it had the base map suited for my setup, but now the setup has changed. what i HAD when i ordered it was this:
stock S5 TII motor
hybrid S4 turbo
FMIC
680cc prim.
800cc sec.
full 3" exh.
everything is the same except now i have 1680cc sec. and a to4e .60/1.15ar.
can anyone tell me the things i need to adjust and how to change the injector size?
i gotta make a trip from houston to dallas in order for steve kan to get his hands on this thing before i screw it up...
i really appreciate any help.
Old Apr 12, 2005 | 07:50 PM
gergrx7's Avatar
Boosting Again
Use a wideband and tune it according to your injectors, there is no where you can just say " i have this thsi adn this" and get it to run right. You should go into normal mode adn adjust teh figures 20"-0"hg since you should boost it untill its really tuned.
Old Apr 12, 2005 | 10:34 PM
seven-less
ah, i get it then... so it should be fine to just start her right up and go from there? (plus setting the TPS, etc.)
