i got my comrpression tests results
Old Dec 27, 2001 | 01:43 PM
kam's Avatar
kam
these are my numbers rear rotor:7.7 7.8,7.8
front rotor:9.1,8.9,8,8
are these good reading or what???
Old Dec 27, 2001 | 01:46 PM
vosko's Avatar
Just Call Me Terminator!
front is HIGH which is very good. rear is still in specs . your compression is good.
Old Dec 27, 2001 | 05:22 PM
Johnny's Avatar
OG
Yep..what he said...
Old Dec 27, 2001 | 09:44 PM
Nathan Kwok's Avatar
WOW!!!! Thats amazing, because 8.5kg/cm2 (120psi) is the new factory spec, so your front rotor is higher than factory spec. Just curious, what rpm was it done at? Also, the difference between front and rear is bordering what is normally considered acceptable (1.5kg/cm2), but the numbers are so high, I wouldn't worry! To be honest, as long as the car doesn't show any symptoms of low compression (ie floods easily, hard to start, etc.) it doesn't really matter, just drive it!
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
Mps_hell
Sep 19, 2015 10:02 PM
localized
Sep 16, 2015 12:18 AM
