Power FC Apexi Power FC Pin Schematic
Old Apr 8, 2005 | 03:03 PM
Hugh Sperry's Avatar
I've searched several forums with no luck---Anyone know where I can find a schematic for the Power FC?
I can look at the connectors on my wiring harness and back into what each pin does but am uncomfortable doing it this way.
Old Apr 8, 2005 | 04:01 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
you didn't search far away man... just look at the Power FC Installation sticky thread on the top of the power fc forum.
Max
Old Apr 8, 2005 | 04:41 PM
Apexi Power FC "Schematic"
What I'm looking for is a "schematic" similiar to the one in the RX7 manual.
All I can find anywhere is a picture of the plug in connector on the ECU showing which wires to clip. I want to know what each input pin controls---No documentation in the Power FC instructions illustrate this (that I can find).
Old Apr 10, 2005 | 02:36 AM
bolo_fd's Avatar
aren't they the same as the rx7 manual?
Old Apr 11, 2005 | 08:56 PM
The connectors may look the same but the various inputs / outputs must be different (I think) as this ECU is not controlling many of the solenoids the stocker controls; EGR, pre-spool, relief valve 1 &2, charge control, waste gate etc...
Taking this on a different direction, can anyone direct me to a certified Apexi dealer / technician. I'm willing to pay to get this information.
Old Apr 13, 2005 | 10:17 AM
DaleClark's Avatar
RX-7 Bad Ass
All the wiring to the PowerFC is identical to the stock layout - just ignore the 4 wires that are cut, that's it. That's why you can plug the PowerFC straight into the stock harness and it works.
Section F of the shop manual has the ECU pinouts and outputs documented to death.
Dale
streetlegal?
Mar 17, 2022 02:46 PM
