center bore and thread type on FC
For the FC,thread is 12x1.5mm and center bore is 59.5mm(some of the other mazda's have a 67mm centerbore),toyota supra's(late 80's) have a 60.1mm centerbore so if you are looking at something like an H&R spacer you could use one those also,but they did list an application for the 929 with the correct Bolt pattern and centerbore that is the same as the FC.
20B Forum
Aug 18, 2015 02:46 PM
