Power FC Now The Datalogit AND Commander are not responding
Old Apr 7, 2005 | 07:28 PM
tookwik's Avatar
VIP - Very Irish Person
Any help here would be greatly appreciated. The story is simple; I have the datalogit with the PFC and now whenever I start it, like I've always started it before (and it worked), I get an 'interface not responding' window. When I try to use the commander, the damn thing is stuck on the intro Apexi screen. What in the world am I suppose to do? Thanks in advance.
Old Apr 8, 2005 | 05:43 AM
subyfiles's Avatar
In contrary to you, I cant start FCbox if the commander unplugged! When I plug the commander it works. weird!
Old Apr 8, 2005 | 06:12 AM
tookwik's Avatar
That is wierd! Its like it needs a compete circuit or something?!
Old Apr 8, 2005 | 08:39 AM
cewrx7r1's Avatar
Eye In The Sky
Electronics do fail sometimes.
My original cable between the DATALOGIT and laptop went bad after three years of use.
It might be that or the cable that plugs into the PFC or the DATALOGIT itself, or your laptop. Time to start checking. Easier if you know someone with same equipment.
Old Apr 8, 2005 | 01:35 PM
tookwik's Avatar
oh no, yea i think i'm going to tear into things in the next hour or so. Are the commander and box warrantied?
Old Apr 8, 2005 | 05:43 PM
tookwik's Avatar
Alright well I think its the actual FCBox because when i plug the commander directly into the ECU everything works fine. Any more ideas? Could it be due to me plugging the Clutch Switch Wire into the SW-3 slot and maybe putting the wrong wire in? Meaning the positive one and not the negative? I'll try unplugging that next. Any ideas would be greatly appreciated.
Old Apr 8, 2005 | 07:19 PM
cewrx7r1's Avatar
Eye In The Sky
One I do that many do not do is: whenever plugging in, or un plugiing, have everthing turned off! This prevent voltage surges which can mess things up.
Old Apr 10, 2005 | 10:26 PM
tookwik's Avatar
well, im going to try re-initializing the pfc. What exactly does that do? I won't loose the data already stored on there will I?
btw - when you press the WRITE ALL button on the datalogit, which file does it write and store to the pfc? Is it just the default.exe or does it write witch ever map you have open?
Old Apr 12, 2005 | 09:48 AM
TailHappy's Avatar
Addicted to Track
Like Chuck said, be sure to check your wires and plugs. I had the plug on the datalogit go bad (due to my stupidity..had it squished on the ECU bracket), so it was flakey when the datalogit was hooked up, but connecting the commander directly to the PFC would work. Try jiggling the connectors and pushing them in different directions to see if it changes anything. I also had the socket on the PFC itself come loose...
Old Apr 12, 2005 | 10:44 AM
tookwik's Avatar
Yea, I checked all the pins, all the connections... I guess I could wiggle them a little more but still. I really think its fried or something.
The commander still works when i plug it directly into the Apexi.
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
