Is my TPS really bad?
Old Apr 7, 2005 | 02:48 AM
RX*TooNER's Avatar
So I have ohmed out a total of two tps's:
As resistance increases... there is a short moment where the meter does read "OL". But then about a second later it seems to be sweeping up fine. The only thing I can think of is that its the meter changing values from ohms to k ohms.
Both TPS's that I tested have done this...
So my question is.... Did I just so happen to get two faulty tps's or is it actually the way meter is operating?
Old Apr 7, 2005 | 08:29 AM
zeromage428's Avatar
BWAAA
i have 3...2 of them are bad if that helps, well one of those 2 i tried to disect n ghetto rig it with superglue....but that didnt work well because of the engine heat, so i said screw it and got a new one, a new used one
Old Apr 7, 2005 | 08:55 AM
SureShot's Avatar
Seduced by the DARK SIDE
A cheap (<$10) needle type meter is sometimes better at observing the sweep of the TPS values.
BTW: If you can do soldering & heat shrink, the plugs & brackets can be swapped from different models.
The actual plunger resistors are all the same.
Old Apr 7, 2005 | 09:02 AM
BWAAA
do the (tps)s affect how your car runs???
Old Apr 7, 2005 | 10:31 AM
SureShot's Avatar
Yes - If the ECU gets an "idle" signal from a bad spot in the TPS sweep & the RPM's are above 1500, you will get a fuel cut.
link to short video of a bad TPS
Donald Hampton
Sep 20, 2015 09:09 PM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
