will a bigger fuel pump for now protect me from running lean?????
Old Dec 26, 2001 | 10:00 PM
kam's Avatar
kam
hey bros, i'am think of going to a bigger fuel pump for now to prevent any detonation, because i dont have the money to get an upgraded ecu, i was wondering if i will be protected from running lean with a bigger fuel pump
Old Dec 26, 2001 | 10:12 PM
the_saint's Avatar
Exclamation
Hello Fellow Canadian.
What other modifications do you have or have you done?
A higher flowing fuel pump will not prevent detonation. I would spend the money on an upgraded ECU/EFI PMS/Apexi PFC, it is much cheaper than a new motor. Even with ECU mods it is possible to blow your motor.
the_saint
Old Dec 26, 2001 | 10:43 PM
kam's Avatar
kam
i have just ha ve down pipe and midpipe
yeah my mods are just a down pipe and midpipe
Old Dec 27, 2001 | 12:46 AM
the_saint's Avatar
Question
How much boost are you running? Do you have any problems keeping your boost in check? I wouldn't run more than 10 psi of boost without any mods to your ECU, otherwise you will run into fuel cutoff, or excessively high pressures and experience a wonderful case of detonation.
the_saint
Old Dec 27, 2001 | 12:47 AM
dis1's Avatar
www.silverbulletrx7.com
With no cat back or intake you should be safe but it still depends on boost. That combo can produce nasty spikes along with boost creep. Also a fuel pump can cause a rich condition because contrary to common sense a fuel pump will increase fuel flow regardless of your ECU. (One would think it would just increase max fuel potential.) If I were you I would be careful. It's better to take things slow than to haphazardly throw upgrades on to your car. If you decide to go with just a pump get a dyno tune by a reputable Rotary shop to make sure you are safe.
Old Dec 27, 2001 | 01:22 AM
kam's Avatar
kam
i'am running 10 pounds of boost with midpipe and downpipe
the boost levels i'am running at is 10 pounds
alphawolff
Nov 17, 2015 05:57 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
