Power FC ? about Power fc & how do u reset it?
Old Mar 30, 2005 | 09:53 PM
Rx7aholic's Avatar
Hey I just a Power fc used, anyway it's tune for a single turbo kit. I don't have single I am still running oem twins sq. I have few questions but I want to know if there map for all type of mod's setup? I am planning to change my fuel setup by next week, I got aftermarket fpr,and I planning to buy 1000cc for kdr secondary rail, and new 550's. My mods are intake, Dp,H-f cat, RB dual tip catback, PFS I/C. plus the new fuel setup, what maps will I need to set the pfc? thanks alot, khris
Old Mar 31, 2005 | 08:54 AM
cewrx7r1's Avatar
Eye In The Sky
Reinitialize the PFC and see if it goes back to a stock configuration. If it does, then next you would change the secondary injector size to match your new 1000cc secondaries.
Old Mar 31, 2005 | 09:40 PM
Rx7aholic's Avatar
Hey Chuck I can't open that file is there any other way I can view it? Also does the pfc give u an option of all type injectors size to map it to it? khris
Old Apr 2, 2005 | 08:26 AM
cewrx7r1's Avatar
Eye In The Sky
After you UNZIP it, it contains an EXCEL format of IGL, IGT, and split for stock engine about 1998+. This site does not allow an EXCEL attachment.
If you read the PFC manual, it tells how to chnage injector size up to 1500. For larger you will need a DATALOGIT.
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
rx7shirley
Sep 2, 2015 02:11 PM
