engine flooded
Old Dec 24, 2001 | 11:28 PM
Kouki_1st_Gen's Avatar
engine flooded
do i need to replace sparkplugs? or just pour atf or water? in the spark plug whole. and how much do i need to pour in?
Old Dec 25, 2001 | 02:13 AM
yayarx7's Avatar
Are you Nucking Futs?
if indeed you have a flooded car, pull all of the spark plugs out of the car. Pull the fuse for the fuel pump. turn the car over for about 30 sec or until the gas quits shooting out of the spark plug holes. Replace the spark plugs and reinstall the fuse and see if that did the job.
Good luck
Old Dec 25, 2001 | 03:51 AM
flooding
what would cause the engine to flood?
Old Dec 25, 2001 | 09:43 AM
Pittdp's Avatar
low compression can cause the engine to floood. And when it gets really cold our cars have less compression than in the warmer weather.
Old Dec 27, 2001 | 10:35 PM
rxtasy's Avatar
i assume you have a gsl-se . They have been known to flood a lot, especially when you only run them a few minutes (say to move them) and shut 'em off without reaching 'normal' operating temps. it's only happened a few times to me, but i've always got it going the 'quick' way.
1. remove the blue wire from the trailing coil
2. with the gas pedal pushed FULLY TO THE FLOOR, crank the engine.
3. it could start right away, and then sputter out.
4. put the wire back on the coil and start the car as normal (don't touch the gas pedal this time)
I've got it going every time that way. IF it is REALLY REALLY flooded you have to do it the long way removing plugs, etc. here is a link that describes the proceedure pretty good...
http://www.rx7.com/tech/unflood-se.html
the link used to take you right to the article but i think it only goes to the home page now so once there click on "TECH INFO", then "13B Common starting problems"
hope that helps.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
PhillyFC
Aug 21, 2015 06:36 PM
86glxNA
Aug 18, 2015 03:33 PM
zuesskroph
Aug 13, 2015 06:05 PM
