An Estimate hp and tq with this setup
Old Mar 28, 2005 | 01:52 PM
7777 Nepok 7777 -rx-'s Avatar
Hey, around what hp and tq would this single turbo setup produce?
NEW 13B ENGINE ( MILD PORT STAGE 1)
GREDDY UNDER PULLEY SET
SHIMMED CRANK ANGLE SENSORS
TURBO GARRET T04S
XS ENG. CAST EXHAUST MANIFOLD
APEXI BOV
HKS RACING 50mm WASTEGATE
KOYO 2-ROW RACING ALL ALUMINUM RADIATOR
NGK IRIDIUM SPARK PLUGS
ACT STREET/STRIP HIGH PRESSURE PLATE AND CLUTCH DISK
CUSTOM FULL 3" SS EXHAUST SYSTEM
K&N AIR FILTER
SILICON VACUUM HOSES
CUSTOM GROUNDING HARNESSES
MASTER AND SLAVE CYL. DOT 5 FLUID
Old Mar 28, 2005 | 04:34 PM
come on ppl, its almost a regular single, no one knows this?
Old Mar 28, 2005 | 05:23 PM
XSTransAm's Avatar
Ee / Cpe
check this site out, it has alot of plots, im sure you can find something similar to your setup.
http://dyno.zeroglabs.com/dyno.php
but the best way to know is to put it on a dyno and see for yourself.
Old Mar 28, 2005 | 05:30 PM
i will check it, anyways if someone happens to know some aprox numbers it would be nice
thanks transam
Logan Reinisch
44
Sep 17, 2018 12:20 PM
eplusz
15
Oct 7, 2015 04:04 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
