What do i do now??
Old Dec 24, 2001 | 08:14 PM
crossbar17's Avatar
Question What do i do now??
I have done the following mods and i am not sure of what to do next:
cold air intake
Greddy HIgh flow mufflers
test pipe cat replacement
5th and 6th ports open electronically at 3600 rpm's
10mm plug wires
NGK plugs
Power Pulleys(maine & alternator)
removed ACV and air pump as well s EGR valve & made block off plates
tII fuel pump
slightly advanced timing
TB mod
Ported upper and lower intakes
what do i do now??
i want to stay N/A though
how fast do u think my car is now?
crossbar
Old Dec 24, 2001 | 08:31 PM
crossbar17's Avatar
this is a 88 SE n/a and i have stock wheels and plan to keep them for performance reasons
Old Dec 24, 2001 | 08:34 PM
Yelow RX-7's Avatar
Swingline Stapler
you can get underdrive pulleys, headers. actually, Racing Beat sells a Header/Presilencer package. you should check it out.
Old Dec 24, 2001 | 08:35 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
I was about to suggest lighter wheels and better tires. The BBS convertible rims are 15x6.5 and only 15.5 lbs... and look good on there. You ARE 5-lug, right?
Do you have LSD? If not, I'd look at that next. Also, the 4.3 gears from a GTUs would help a bit. (Best is to just find a 4.3 GTUs diff and swap the whole thing... IF you can find one...)
A Mustang AFM and S-AFC MIGHT be good... but I haven't tried this out just yet.
Old Dec 24, 2001 | 08:41 PM
Yelow RX-7's Avatar
Swingline Stapler
so wait, can you put a GTUs differential on a 87 N/A?
Old Dec 24, 2001 | 08:44 PM
crossbar17's Avatar
whats LSD? and no i have 4-lug wheels but bought the car with a whole knew front end and new brakes and pads
nobody say radiator cause i have a high flow griffin one installed and a Perma-Cool fan on the way that is 2,950 CFM of flow
~~crossbar
also my power pulleys stated are underdrive and i have done the electrical upgrade suggested by many people...as my list gets longer i tend to forget things that i have done
Old Dec 24, 2001 | 10:20 PM
Silkworm's Avatar
Has been.. hangin' around
Go racing.. Once it thaws out, I'm sure you can find auto-xs in your area. It's a timed event held in parking lots, where you can push the car to it's potential instead of buying stuff to buy stuff. Stop f'ing with the car, go have fun with the car.
But if you HAVE to buy something.
5 lug conversion and 4 piston front brakes from a GXL
Rear differential from an 86-88 GXL (LSD equipped)
Racing Beat Header
Urethane Bushings
Toe Eliminator Bushing
Headlight Cover intake thingie
Paint it (if it needs it)
But it's still slow straight line, I don't care if you do all that or not. You want speed, big ported motor or T2. Period. Sorry if that offends some of you, but that's my opinion. 14s is slow. 13s is slow. 12s is getting there, 11s for a true street car is doing good.
Cya!
PaulC
