what is better: Single turbo or Twin Turbo and why?
Old Dec 24, 2001 | 04:30 PM
Yelow RX-7's Avatar
Swingline Stapler
what is better, single turbo or twin turbo? and why?
Old Dec 24, 2001 | 05:12 PM
HWO's Avatar
HWO
inteligent extratarestril
a truely perfected sequential twin turbo setup will have the same top end HP as a huge single will but it'll pull 10+ psi from approx 1500rpm if its sized and set up right
I think it'd need a twin entry primary turbo, a mass of control lines and a large headache to get it working correctly.
Old Dec 24, 2001 | 06:18 PM
MeLoco's Avatar
A truly perfected single that is sized correctly would offer the same response as a sequential and give you the high end HP as well.
without the headache
Old Dec 24, 2001 | 06:30 PM
Yelow RX-7's Avatar
Swingline Stapler
can you post a picture of a twin turbo set up? preferably aftermarket, but stock will do too.
Old Dec 24, 2001 | 08:13 PM
HWO's Avatar
HWO
It is an impossible task
Go out and find a single turbo 'perfectly sized' as you put it, that will happily blow 30psi worth of air to give ya 700 or more HP at 9000rpm, while still able to spool and blow 10-15psi before 2000rpm.
The idea of a single turbo is to create and happy medium depending on what exactly you are looking for, a true sequentail system could give you the max possible power available at all rpm from idle to 9000rpm
Old Dec 24, 2001 | 08:20 PM
Yelow RX-7's Avatar
Swingline Stapler
whats a sequential?
Old Dec 25, 2001 | 02:50 AM
HWO's Avatar
HWO
its a twin turbo system in which all the flow goes into one of the turbos then splits off to run some into each turbo.
Old Dec 25, 2001 | 07:59 AM
13BAce's Avatar
On a long vacation
Yup. There's no way to do it, unless there's something we don't know.
Old Dec 25, 2001 | 09:17 AM
Bacon's Avatar
IRS 4 Life
single--less complicated..more power
why buy 2 when you only need one?
Old Dec 25, 2001 | 10:41 AM
Yelow RX-7's Avatar
Swingline Stapler
yeah but which one spools up faster and which has the worst lag? in general.
Old Dec 26, 2001 | 01:19 PM
MAESTRUL's Avatar
My turbo!!!(Apexi MASTER)
Yeap, it spools up fast, no lag and
THE MOST IMPORTAND-NO HEADACHES
http://www.rx7forum.com/attachment.php?s=&postid=243964
Old Dec 26, 2001 | 03:21 PM
MeLoco's Avatar
:o
Old Dec 26, 2001 | 03:26 PM
MeLoco's Avatar
First off I was playin, second off you said a truly perfect sequential setup, which can only happen in a truly perfect world, so unless you and all the other manufacturers out there suddenly can meet the requirements you just explained you need to relax. Unless you know something I don't, I don't know of any sequential setup that hits 10lbs before 2000 rpm and still blows 30 by 9000k a sequential setup IS the compromise adding both complexity and weight to try and achieve low rpm response combined with high rpm power.The setup I am working on on my car shows positive boost by 2200 rpm gives me just under 10lbs at 2800 14.7lbs by 3400 and will run 28lbs when needed The turbo also happens to be rated to flow at guess what; 700hp.
I can also run a smaller a/r and get even better response but then it would only be rated at 600hp. Now I'll take that setup with less weight and less complexity and as good response as stock with the ability to run CLOSE to that 30lbs/700 mark any day over your truly perfect but not quite real more complex and weighty setup anyday, and next time I guess I'll be more careful on who I kid around with.
Old Dec 26, 2001 | 11:00 PM
HWO's Avatar
HWO
i never saw the at the end of ya post
Old Dec 27, 2001 | 07:48 AM
MeLoco's Avatar
Thats cool, Happy holidays just in case
Old Dec 28, 2001 | 04:45 AM
Jordan's Avatar
Dood, you'd better let me know what's going on with your camera, I've been waiting for 2 months after I said the money to you.
check your email.
If you still not gonna reply, I think I have to do something in order to defense.
GOOD LUCK
Aug 21, 2015 08:35 PM
Turblown
Aug 14, 2015 04:48 PM
