Power FC pfc sensor reading clarification?
Old Mar 23, 2005 | 03:04 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
so in datalogit, in the monitor window, there are a few sensor labels i need clarification on:
- VMOP
and
- FUEL
I am guessing vmop may have to do with oil metering pump? and FUEL is the fuel rail temp sensor?
Old Mar 23, 2005 | 06:15 AM
maxcooper's Avatar
WWFSMD
I think VMOP is "voltage sent to the metering oil pump". The unit is volts, so it doesn't readliy translate to anything useful in terms of oil flow. But I suppose you could compare to other VMOP readings (different maps, different spots on the same map, before/after if you change the MOP settings, etc.).
I'm not sure about FUEL. Fuel temp? Does it correlate with the other fuel injector control readings (ms, duty cycle, etc.)? What does the FC-Edit manual say about it?
-Max
Old Mar 23, 2005 | 10:55 AM
DaleClark's Avatar
RX-7 Bad Ass
I would guess FUEL would be the fuel temp sensor in the fuel rail. That's mainly an input for switching the FPR to atmospheric pressure, but in theory the ECU could also use that input for fuel or timing calculations.
Dale
Old Mar 23, 2005 | 11:04 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks for the info guys, ill check the pfc manual too, but im pretty sure between us we got it right.
Old Mar 23, 2005 | 11:36 AM
CANRX7GX's Avatar
PREDATOR
I have the owners manual on my desktop. Send me a pm with your email if you want it
rgordon1979
40
Mar 15, 2022 12:04 PM
troym55
23
May 25, 2016 12:42 PM
ZacMan
Sep 19, 2015 09:20 PM
doritoloco
Sep 5, 2015 12:41 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
