Power FC PFC map problems?
Old Mar 22, 2005 | 10:35 PM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
Question PFC map problems?
I am no expert and I couldnt find any faults with my pfc map. It was tuned by Steve Kan. I am on my 2nd motor with this map (first one lasted about 5 days) and wanted to see if anyone could check it out for me. maybe I am missing something.
Mods are:
Stock port / DP/ High flow cat / cat back / intake / medium SMIC / 550 and 1300 cc injectors / no emissions / running 14 psi
nothing against Steve, I just want to make sure this map will be ok to add fuel and use a wideband to get the A/F ratio back to the right spot. also, while the car was down I removed double throttle and ported the TB and UIM.
I am mainly concerned with the timing and other variables.
Thanks for any help.
File Type: zip
Old Mar 23, 2005 | 06:06 PM
resU deretsigeR
TTT
pretty please?
Old Mar 23, 2005 | 08:55 PM
cewrx7r1's Avatar
Eye In The Sky
For 14PSI boost, at max torque, you are running about 2 degrees more advance than me and from N16-N20 not enough advance.
Would not have blown your engine if all componets were operating properly as I run a MP and large FMIC.
I will not commnet on fuel as this will vary more between cars with similar setups than timing.
Old Mar 23, 2005 | 10:32 PM
Jodeny's Avatar
Indifferent
This motor blew at 14 psi?? Did you spike it past there?
John
Old Mar 24, 2005 | 10:11 AM
resU deretsigeR
no spike. however, after the motor blew, I was going through everything and the rev limiter was left at 8400 from when it was tuned. dont know if that would kill it, but I would think it didnt help. it was cold outside and I took off in 1st and the tires spun til redline very fast and it hit 8400 before I could let off.
Thats another thing Im worried about, is the temp correction. while tuning I was seeing 50 C intake temps...and on cold nights I worry about it.
thanks for the comments so far.
Old Mar 24, 2005 | 11:32 AM
twokrx7's Avatar
Need more sleep
What gear/rpm did it blow up at and what failed inside the motor?
Did you have the commander saving any peak info during the blow up? knock, boost, etc?
Old Mar 24, 2005 | 03:21 PM
resU deretsigeR
I was in first gear and I didnt hear anything break/blow...in fact I didnt notice it was blown until a little further down the road. it cracked a seal on the rear rotor.
I did have a commander, but I was too caught up on the fact that my motor took a dump and I didnt think to check it.
Old Mar 24, 2005 | 03:56 PM
bolo_fd's Avatar
i remember reading that the rev limiter is bumped up so it wont come on because it does more harm then good. i'll look around and repost later
edit: our cars use fuel cut when over reved and that will make our engine run lean and add the high boost level that can become a very big problem
Old Mar 24, 2005 | 07:01 PM
cewrx7r1's Avatar
Eye In The Sky
The stock location of the air temp sensor and the AIR TEMP vs INJ table is crap for a modded engine. First since the stock ECU runs so rich for normal air temps, it actually leans out the engine when it gets cold. Thus If you AFR tuned in warm weather for a leaner AFR like 11.3, most likely in cold weather you went leaner than 12. Also it heat soaks under the UIM.
That is why many of us have suggested moving the ar temp sensor to the throttle body inlet elbow or IC outlet. Then you have to normalize the table to real air density vs temperature which also has been discusses here before. Not doing so is asking for problems.
Old Mar 26, 2005 | 01:20 PM
Robertio's Avatar
Compared to what I used to run the timing map is conservative, but you're obviously running on diferent fuel so not directly comparable. If you are concerned then just take a few degrees out the IGL map under boost, sort out the fueling then try adding it back in a degree at a time.
Would also keep a careful eye on boost, just in case your porting work, etc result in you seeing somewhat more than 14psi (probably best to err on the side of caution initially - better too have too little boost than too much).
Probably best to get a better rev limiter than the PFC, yours wont have been the first engine to come a cropper because of it.
Old Mar 29, 2005 | 07:08 PM
books's Avatar
Chuck,
When you compared 14 psi from your map to Kan's did you notice his map reference for his P rows were changed?
Old Mar 29, 2005 | 07:38 PM
books's Avatar
one other observation, rows P17 and P18 have the identical timing for cells N10-N20
I believe these rows are around 14 psi.
Because these rows are the same any averaging of bordering rows, would result in higher average values when compared to most maps since the timing values usually decrease as boost increases.
Old Mar 30, 2005 | 10:45 AM
pluto's Avatar
I ususally don't retard the timing on anything after 14psi. It does nothing but creating heat.
Also, how long did you stay at the rev limiter before you let off or shift? I have seen engines cracking corner seals and apex seals from hitting the rev limiter on pump gas. Also, were you low on gas when it happened? If so, I wonder if it could pick up air bubbles from the tank causing the car to run lean. I have only seen one other car that blew his engine in 1st gear and that was with him staying on the rev limiter for over 5 secs.
Old Mar 30, 2005 | 01:49 PM
cewrx7r1's Avatar
Eye In The Sky
Chuck,
Yes, as I did a map compare first.
Old Mar 30, 2005 | 02:00 PM
books's Avatar
Pluto,
My statements were merely an observation. I certainly respect your tuning talent. I had just noticed there were few timing changes for rows P17 and up and was wondering why… since, I have seen some other maps where the general trend was to lower/retard timing up to P20
Old Apr 1, 2005 | 10:08 AM
resU deretsigeR
Pluto,
I was at the rev limiter for no more than a second. However, I was low on fuel and had figured that could have been part of the problem. I am not so concerned with the old motor blowing up as I am with my new one.
Would porting(smoothing) the TB and removing the double throttle and porting the UIM create too much air flow and make the car run lean?? I plan on getting a wideband and basically adding some fuel to all the boost cells and lean it out to 10.8-11.0 from there.
Old Apr 1, 2005 | 12:10 PM
pluto's Avatar
You might run just slightly leaner with the porting of TB and UIM. The map that I tuned should have plenty of margin to compensate for it. But like you said, the best way to verify it is to use a wideband.
Pluto,
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 15, 2015 04:45 PM
msilvia
15
Sep 11, 2015 12:13 PM
befarrer
Sep 4, 2015 08:26 PM
