Microtech installed a microtech lt-10 and can't get it tuned right
Old Mar 19, 2005 | 08:58 PM
seth'sbridreport's Avatar
my89bridgeport
i have just installed a micro tech lt-10 and when i went to go dyno it, it would not tune right. we got my 89 bridgported engin to idle but it took 15 degrees of timing to do. when we put it on the dyno we could not get it tuned, we changed the timing almost a full 40 degrees but the hp would only chang 1-3, and the torque would not change at all. we had it on the dyno for 3-4 hours before we gave up for the night[SIZE=3]. does any one out there know why it is doing this? [/SIZE]
Old Mar 20, 2005 | 01:05 AM
jacobcartmill's Avatar
just dont care.
mmmmm 40 degrees... sounds like bad times.
Old Mar 20, 2005 | 10:05 AM
my89bridgeport
do you have any idea why it is doing this?
Old Mar 20, 2005 | 04:16 PM
10sec rx7's Avatar
maybe you dont have the fuel maps right??
15deg timing at idle is nothing for a bridge port, i run up to 20deg on a half bridge at idle
take the car to someone that knows what they are doing...
have you ever thought that you might be on the limit with the timing and putting more in is not going to make any more power only increase the chances of detonation??
have you got the static set correctly?
Old Mar 23, 2005 | 11:59 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
the timing is zero'd out, isn't it?
Old Mar 24, 2005 | 03:09 PM
FC_mania's Avatar
u guys zero'd your timing with the leading mark or did u remark your pulleys?
Microtech
30
Apr 23, 2016 06:37 PM
dkwasherexd
Far East Forum
Aug 17, 2015 11:26 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
