what are these wires?
Old Mar 18, 2005 | 05:25 PM
RevZempoe's Avatar
Trying not to be stock
Finally got the stock head unit out...one of the wires pulled out and broke, the other has a black rectangular head to it. Which one of these are the power cord and what is the other one for? Looked at the back of my new head unit and it only has a circular input for it.
and
RevZempoe's Avatar
obviously the one on top is the one that pulled off the back of the cd player...
Old Mar 18, 2005 | 06:40 PM
TurboSE's Avatar
the first pic is the antenna cables/the second one is your ground
Old Mar 18, 2005 | 07:08 PM
RevZempoe's Avatar
Ok, the ground has a rectangle head...how do I make that into the round one that most head units use? Is there some sort of adapter? And as for the antenna wires...As you can tell they're not topped off...how do I work with that to connect it to a standard head unit that is using the rx7 radio harness ?
Old Mar 18, 2005 | 10:16 PM
X-JaVeN-X's Avatar
Drive.
the antenna wire is the single wire with the rca plug looking end...it will plug into the round hole on the back of the cd player. The ground wire will come off the radio which you can wire into the harness, OR ground it to chassis (that is what i do on all my radios...direct chassis grounds are much better IMO) To make life easy go pick up a wiring harness from best buy or circuit city...plug that into the factory harness and then match up the colors from that to the colors of your cd player.
Old Mar 19, 2005 | 09:32 AM
RevZempoe's Avatar
javen, you're totally missing what I'm saying bud. Ok ground wire, no problem I'll ground that. The first wire in the picture, it didn't have an rca plug...it pulled out (broke) off the stock head unit. How do I get the RCA looking connector attached to it?
Old Mar 19, 2005 | 12:27 PM
RevZempoe's Avatar
went up to best buy and got some answers . apparently the two wires seperate are just to assist the stock unit with reception but with an aftermarket unit you only need one. I need a male to male extension to be able to hook it up to the aftermarket unit. it was a male to board connection that it came with (just connect directly to the board through a 2 pin connector)
Old Mar 19, 2005 | 04:57 PM
RevZempoe's Avatar
is the black wire in the back of a head unit the ground? If so...how is it possible for a unit to run without the ground hooked up to something?
Old Mar 19, 2005 | 06:11 PM
X-JaVeN-X's Avatar
Drive.
alot of times the antenna is grounded and depending on the car/radio can provide enough of a ground to power up the unit...though I wouldn't recommend using it your permanent ground
Old Mar 19, 2005 | 06:21 PM
poo_on_u's Avatar
I called best buy and they haven't even heard of the male to male connector for intalling an aftermarket head unit. My antenna isn't working and I have the the same problem you do Revzempoe, so if you fixed your antenna can you further elaborate on it.
Old Mar 19, 2005 | 06:22 PM
RevZempoe's Avatar
well the problem I have, I'm getting some severe static out of my front speaks (only 2 hooked up atm) I get the static whether i have the unit grounded or not...any ideas?
Old Mar 19, 2005 | 06:40 PM
poo_on_u's Avatar
maybe double check the wiring.
Old Mar 19, 2005 | 07:47 PM
RevZempoe's Avatar
yeah poo, I got the antenna part fixed now no problem. View the first picture. you see that 2 wires become one. Where that insulation is, that's where the 2 antenna wires connect. Need a male for that. then, on the other end you need a male to connect to your head unit. I'll take more pictures tomorrow. I've double checked all wiring...still staic. I don't know.
Old Mar 20, 2005 | 12:14 AM
poo_on_u's Avatar
Sorry can't think of anything else but thanks for helping me.
Old Mar 20, 2005 | 09:17 AM
RevZempoe's Avatar
yeah I'll get ya pics here in about 30 mins when it's a lil warmer out
Old Mar 20, 2005 | 10:05 AM
RevZempoe's Avatar
that last picture is what you need. in the first picture it was to show you the 2 antenna parts. one is just assistance for the stock unit. show best buy that last picture. they can make it. was about 20 bucks...
Old Mar 22, 2005 | 10:47 PM
poo_on_u's Avatar
thanks that last pic helps a lot!
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
