Microtech where to get harness plugs?
Old Mar 16, 2005 | 03:05 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
ok so where do you all get the plugs you install on your m.t's? im talking about the plugs to hook to all the stock senders and the injectors and such?
Old Mar 17, 2005 | 09:36 PM
Crusader_9x's Avatar
I got mine off my stock harness. the injector plugs i got form my friend that works at a volvo saab shop.
Old Mar 18, 2005 | 03:31 PM
Aaron Cake's Avatar
Engine, Not Motor
Replace all the cheap, outdated Mazda stock connectors with new WeatherPack connectors. GM/Ford style, available at any auto parts store. Don't waste time hacking apart the old harness.
Old Mar 21, 2005 | 05:41 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
kool, yea i plan on getting all new plastic clip/plugs to install on my lt8. Why do it half assed you know. So did the new plugs have the plastic only or did they also have the right metal pins/ insert clip deals? I plan to solder and heat shrink EVERYTHING so i know im not getting a bad/poor connection.
the next install issue will be a good location to mount the box in my 83
Old Mar 22, 2005 | 10:58 AM
Aaron Cake's Avatar
Engine, Not Motor
Some kits come with everything, and with some you need to buy each side and the pins seperately.
ZacMan
Sep 19, 2015 09:20 PM
