Where to buy T04 rebuild kit?
I need to find a Garrett t04 rebuild bit, but after much searching I can't find anyone that carries one.
ReTed says on his website that they go for about $100-150?
He also says to use the "carbon" seal and not the "dynamic" seal.
I also want the kit to have the 360 deg. bearing instead of the 270 deg. bearing.
Any clues as to where to get one of these?
-a
-a
I was in the hunt for one of these as well, turns out that I really don't need it and the turbo I have is fine.
Point being, I was told by a friend here that the best place for a kit is any kind of diesel repair shop for trucks, they usually have these kits available that they can order in. Check it out in your yellow pages and start calling around.
Online I couldn't find she-it.
you can find t3/t4 rebuild kits on e bay. actually you can even find prebuilt center sections on e bay too, all you have to do is move everything from the worn turbo to the new center section. i dont think balancing will be required since you're using the same compressor and turbine wheels. good luck
