255/xx/17 tire sizes? What aspect ratio?
Old Mar 12, 2005 | 04:56 PM
$150FC's Avatar
Currently Winning
Hi guys.
Apparently tire companies don't make 255/35/17? Should I go with 255/30/17 or 255/40/17? The miata tire sizing calculator (http://www.eunos.com/tirecalc/) says the 30s will have almost the same outer diameter as the stockers but I don't know if I want the same outer diameter as my dinky 185/60/14 wheels.
Thanks,
Victor
Old Mar 12, 2005 | 06:58 PM
Rxmfn7's Avatar
Do a barrel roll!
255/40r17 is about perfect. Thats what I run in the rear, and will be running on all 4 in the future with my new fender and wheel setup. The 255/40r17 is .3" smaller in diameter than the stock 205/60r15s on 15" wheel equipped FCs.
Old Mar 12, 2005 | 08:55 PM
rynberg's Avatar
Thanks,
Victor
No, you DON'T want the same diameter as you are running the wrong tire size! Base 86 FCs came with 185/70 14 tires, not 185/60s!
So, as the above poster said, 255/40 17 is correct (I don't know FCs, so you might have to run 245/40 17 for clearance, which is also ok).
Old Mar 12, 2005 | 09:08 PM
RETed's Avatar
http://fc3spro.com/TECH/MODS/RT/tires.htm
Bookmark it bitch!
-Ted
Old Mar 13, 2005 | 11:46 AM
$150FC's Avatar
Currently Winning
Eh whatever I didn't pay much attention to the $40 tires on my car now 255s will work though.
Thanks, Ted. I forgot you had that page up.
Old Mar 18, 2005 | 02:04 AM
Carl Byck's Avatar
Mad Man
255-40-17 Kumho MX...
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
