Mikuni Help Please
Old Mar 12, 2005 | 01:01 AM
Mikeydred's Avatar
83 Limited Edition
Mikuni Help Please
Just put a Mikuni 44 PHH on my 12A. Everything was going great until it was time to hook up the accelerator cable....It's seems to be way too long. Even with the adjustments you make by turning the bolts. Anyone ever experience this? Any suggestions? Thanks guys!
Old Mar 12, 2005 | 01:17 AM
Rx-7Doctor's Avatar
Cable
If i remember correctly there is supposed to be a seperate bolt on attachment for the cable. you cut the ball off and put it thru a wire stop for adjustment. rx7doctor
Old Mar 12, 2005 | 09:53 AM
trochoid's Avatar
Old Fart Young at Heart
Mine fit fine without changing anything. I didn't cut the end of the accel cable, that wraped around the groove just fine. My electric choke even worked. I didn't cut ends just so I could retofit if needed. It can be done.
Post some pic if you can.
Old Mar 12, 2005 | 10:13 AM
Mikeydred's Avatar
83 Limited Edition
I don't have a seperate bolt on attachment for the cable. Would you know where I could get it Doc? Trochoid, my choke is attached fine. I never posted pics before. I will take pics in a minute.
Old Mar 12, 2005 | 10:20 AM
Rx-7Doctor's Avatar
Mikuni parts
Try rebello racing. 1-925-674-0130. If it did not have the attachment it probably was not originally used on a rotary. rx7doctor
Old Mar 12, 2005 | 12:08 PM
Mikeydred's Avatar
83 Limited Edition
The setup came off a rotary. I have the complete setup. The guy had it mounted to a 13B with the adaptor plate for the intake manifold. I will try to post the pics.
Old Mar 12, 2005 | 12:27 PM
Mikeydred's Avatar
83 Limited Edition
Here's the pics.......
Attached Thumbnails Mikuni Help Please-dsc00007.jpg   Mikuni Help Please-dsc00005.jpg   Mikuni Help Please-dsc00006.jpg
Old Mar 12, 2005 | 12:55 PM
dscsk8er55's Avatar
rx7less right now
Hey man, I have the 44's on mine. I will go out and look at to see if i can give you some sugestions. Also I don't know but are you sure that these are 44's or 40's.
Old Mar 12, 2005 | 01:49 PM
trochoid's Avatar
Ok, here is what you do. The way you set the choke cable is the same way you need to set the accel cable. Take that screw out in the 3rd pic, set your cable sheath in the mounting bracket, wrap the cable around the slot and set it to length with the screw. The end of the cable will just hang out.
Simple and easy.
Old Mar 12, 2005 | 01:59 PM
DAVID GRIMES's Avatar
How About A Cup Of STFU
Simple and easy.
Yep ! What he said is how mine is, too.
Old Mar 12, 2005 | 04:22 PM
Mikeydred's Avatar
83 Limited Edition
Thanks for all the advice guys......I will go give it another try.
Old Mar 12, 2005 | 05:18 PM
Mikeydred's Avatar
83 Limited Edition
That worked! I looked at that screw but I saw the eye opening for the cable end on the linkage and thought it went there. Too simple........Thanks guys!
Old Mar 12, 2005 | 05:25 PM
Misthael's Avatar
I did the same thing Mikey. Hope everything works for you. I still haven't put mine back together yet.
Old Mar 12, 2005 | 07:48 PM
trochoid's Avatar
Don't feel bad, I had to ponder the hookup for awhile myself. My main idea was to preserve the cable ends, and it does work out that way.
Old Mar 13, 2005 | 12:29 AM
Mikeydred's Avatar
83 Limited Edition
It runs!! I kept everything stock as far as fuel pump, just to get it running for now. Still have to set timing. It's making a whistle noise as it idles. I checked the choke by opening and closing it and the choke makes a hissing sound...like a Dellorto. So I'd say the choke works correctly. I'm not sure about the whistle noise it's making. Could it be a vacuum leak?
Old Mar 13, 2005 | 12:55 AM
trochoid's Avatar
If you are still running the stock pump, don't count on it providing enough fuel. I had to upgrade the pump and add an fpr and fuel pressure guage. The stock pump would drop to 3 psi at wot, the mikuni likes 4-4.5.
Old Mar 13, 2005 | 01:05 AM
Mikeydred's Avatar
83 Limited Edition
Oh yea...I have all that stuff. Just trying to figure out the constant whistling noise.
Old Mar 13, 2005 | 01:12 AM
trochoid's Avatar
Play with the choke, moving it in and out, it that doesn't change the whistle, start looking for vacuume leaks.
The mikunis do make a nice sucking sound though. Kinda like money being vacuumed out of your wallet.
Old Mar 13, 2005 | 01:13 AM
Mikeydred's Avatar
83 Limited Edition
Haha....Thanks Trochoid.
Old Mar 15, 2005 | 02:27 AM
deimox's Avatar
Never again I said....
Yeah mine sounds like a vacuum when the choke is on.
Makenzie71
Nov 11, 2003 05:14 PM
