Power FC 1600cc base maps
Old Dec 20, 2001 | 05:27 PM
zkeller's Avatar
1600cc base maps
Does anyone have 1600cc base fuel maps??
Old Dec 20, 2001 | 11:33 PM
Xcessive's Avatar
I'll be running 850cc X 1600cc injectors with a boost kit set for 3bar.
It will take me a few weeks to get the new motor in and run it
on my dyno for the maps, but if your interested in the results I will
post them in the PFC map section.
Old Dec 22, 2001 | 04:18 PM
Dragon's Avatar
20B N/A Wide Body FC3S
I've been running them for a while now and I'm constantly tweaking the map... I'm still having a problem trying to get the 6000-8000 rpm range right under light load p07-p-13 x n13 - n18... I'm getting a little sputter, no knock or anything, it's just annoying... I think maybe it is that there is so much fuel being injected and no boost/not much air flow that it's not atimizing the fuel good enough to get a good burn on... wish I could modify the map to do a shorter, but faster injector pulse.... anyway I'm going to keep playing in this area... I'm also I'm running a large side/exaust port with a To4R A/R 1.0 exaust and 850 primarys. I'm also still running the stock power fc base map (No power excel dealers nearby) and also tweaking the by rpm/boost %'s in the Map sensor adj area and I'm telling it that I have 1450cc injectors, and I'm running 45psi fuel pressure with a Aeroquip 1,000 hp fuel pump, so I'm not sure how many of you my map will help out, I just don't want to post anything that I don't have working perfict in my car yet... If this map will help any of you out let me know and I'll try and get all the info down on paper so I can post it...
Old Dec 23, 2001 | 12:01 AM
zkeller's Avatar
I will be tuning, (attempting to tune), with a wideband over the next couple of days. I just fired her up tonight for the first time since the single conversion. I planned to use the posted 1300cc fuel maps so I have something to work with. I have a T04S and i am going max boost at 17PSI.
I kept the 550 in the primary slot as per Dave at KDR.
danielbradley2
11
Sep 28, 2015 10:44 PM
killerrx710
Sep 24, 2015 10:57 PM
befarrer
Sep 22, 2015 09:33 AM
Mps_hell
Sep 19, 2015 10:02 PM
