Cold start Runs fine, hot start Crap!
Old Feb 21, 2005 | 11:46 AM
altf4's Avatar
Ok car starts and runs great cold, pulls hard and everything even when fully warmed up. But when the car is hot and i try starting it it will idle but idle really low, and no ammount of throttle input with change anything...nore does the choke do anything.
now when i cold start i have a hight idle, but the idle speed screw has an effect on idle, just havne had time to adjust to right.
Also when im running after a cold start it revs fine, but when i get high up in RPM, i get some vibrations.
Old Feb 21, 2005 | 02:10 PM
altf4's Avatar
So far only thing i can think of is sticking throttle plates after shut down.
the fuel atomizing will natuarally cool the carb, but when hot and no fuel to cool, throttle sticks? if so then i have something way out of spec.
Old Jun 25, 2013 | 11:51 PM
Ah Teck's Avatar
Bro see you car have many black smoke ! I konw my car is over rich check your spark plugs fist !
Old Jun 26, 2013 | 04:13 PM
shftin2gear's Avatar
Not sure if this will help, but maybe your hot start assist is broken/malfunctioning? AusRotary.com • View topic - Hot Start Assist Description Please?
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
Wolf_
Aug 11, 2015 04:23 PM
