Power FC power fc again
Old Feb 21, 2005 | 09:36 AM
520hp@26lbsRX-7's Avatar
Bosozoku
power fc again
so after i checked all of the fuses i pulled out the Apex AVC-R boost controller and followed all of the wires and the orange wire was conected to the controller but when i followed it out of the controler it went no ware is that maybe a ground wire or is that my problem.
Old Feb 21, 2005 | 09:42 AM
Bosozoku
hopefully someone will know whats wrong with it
Old Feb 21, 2005 | 09:52 AM
DaleClark's Avatar
RX-7 Bad Ass
The orange wire is for hooking up to an optional switch to use scramble mode on the AVC-R - as in, you press the button, you get X amount of extra boost for Y amount of time.
What is your problem in the first place?
Dale
Old Feb 21, 2005 | 10:01 AM
Bosozoku
I was driving last friday night when all of a sudden I look down at the Power Fc controller and its turning back on like i shut my car off then it gose back to normal reading the boost and rpms. The next day I see that it is doing the same thing but after awhile of driving the car i look down and the controler and it is off and will not come back on. Get home pull all of the fuses out none blown. What do you think happend?
Old Feb 21, 2005 | 10:02 AM
Bosozoku
help
Old Feb 21, 2005 | 10:07 AM
DaleClark's Avatar
RX-7 Bad Ass
It's a bad connection in the commander - do a search, it's been covered before. It's not a hard problem to fix.
Dale
Old Feb 26, 2005 | 12:20 AM
Bosozoku
something deffently happend the controler isnt working. the car starts and every thing works but i have notice that the tach dose not work any more?????
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
