Some Reliability Questions (all out)
Old Feb 17, 2005 | 10:07 AM
TwEaK's Avatar
Rotors? What Are Those?
hey guys ive been on the forums for a while now... i recently purcahsed a 1988 TurboII about 6 months ago, blew the coolant seal (overheated) due to a heater hose broke.. neways i took out the motor and ready to get rebuilt, question is now dad is ragging on my *** because he says our motor cant last anymore than 6 to 8 months. I know about this other post someone posted about daily driving realiability having to fix minor things everywhere... Well i plan to replace all hoses.. freshly rebuilt motor,upgrade turbo,FMIC i do alot of racing and this is also my daily driver any ideas??? MPG does not bother me i love my car and having to pay $15 a day in gas is not a problem =) now heres exactly what im doing and you guys give me a heads up...
Freshly Rebuilt Motor
Brand Spanking new T04B turbo
SS oil cooler lines
FMIC
Try to do SS fuel lines
replace all rubber hoses
clean and calibrate all 4 injectors
and thats about it off the top of my head
i do want to get
aluminum radiator (if anyone is selling one cheap pm me)
and rebuilt tranny and get it shotpinned
so give me some info guys questions and comments always welcomed
please no flaming
THanks in Advance
TwEaK
Old Feb 17, 2005 | 10:58 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
You are sure to blow your engine with that TO4 on stock fuel.
Your father is being optimistic that might last a week the way you are going.
Old Feb 17, 2005 | 11:20 AM
bigturbo's Avatar
yep you need fuel control so at minimum get an FD fuel pump or walbro 255 (50-100bucks), and maybe some 720 injectors(depending how much boost you want to run) and an safc so you can add some extra fuel and then your car should be drivable for a while considing the rebuild was done properly and you adheire to the break in period which is very important on rotary cars.
Old Feb 17, 2005 | 02:41 PM
PureSephiroth's Avatar
#1 Certified Cone Killer
how on earth do you have 900 posts and not know any better?
Old Feb 17, 2005 | 05:54 PM
TwEaK's Avatar
sry to post about it i already have installed
Walbro 255lph (rewired)
720 secondarys
and an SAFC was going to get the car tuned but motor went out
TwEaK
Old Feb 18, 2005 | 07:40 AM
gotrotors?'s Avatar
Well, The fact that a rotary engine doesnt last long is a common misconception. Their reliability is somewhat stifled with big add-ons such as a big turbo, more fuel, etc. If you build them correctly (3mm seals, doweling, expensive coolant seals, not the cheapies, and corner clearancing.) there will not be a problem. Any motor when pushed beyond factory limits sacrifices a bit of reliability. over all, if your motor gets taken care of and you do not detonate, youll be fine for quite awhile. Adam at rx7 specialties has an 80,000 km warranty i believe.
good luck.
Old Feb 18, 2005 | 10:51 AM
TwEaK's Avatar
cheap coolant seals???? what the best kit??? ive heard good things about rotaryaviation...
TweaK
Old Feb 18, 2005 | 06:40 PM
TwEaK's Avatar
bump
_Tones_
May 25, 2021 05:37 AM
t-von
Sep 10, 2015 01:56 PM
mulcryant
Sep 9, 2015 05:24 PM
Nosferatu
Sep 5, 2015 02:13 PM
