Power FC datalogit help
Old Feb 15, 2005 | 09:39 PM
boost_guy's Avatar
datalogit help
I just got my datalogit, my 3 bar map sensor and my injectors. I dont have access to the e-group yet so I was wondering if anybody could help me out. I want to import all of the info on my power fc to my pc. I'm not quite sure how to do it, but I think I just click the read button in the datalogit software. Is this correct?
Old Feb 16, 2005 | 12:39 AM
boost_guy's Avatar
Ok one more question. I try hooking it all up and it says error opening com . what am I doing wrong?
Old Feb 16, 2005 | 01:10 AM
poorboyracing's Avatar
Powered By Craigslist!
try keying on the and then reboot the laptop. if it doesnt work, try change the com port.
Old Feb 16, 2005 | 01:18 AM
boost_guy's Avatar
yeah I tried changing the com port and rebototing but nothing is working. I really need the manual but I havent been given access to the group yet. I've been waiting for like 2 weeks. any other suggestions
Old Feb 16, 2005 | 08:08 AM
TailHappy's Avatar
Addicted to Track
Actually the manual isn't going to help you here. Sounds like you might have a COM port conflict. If you've manually tried all the COM ports and none of them work, then make sure you aren't running some other software such as Palm Hotsync software, which could be trying to use that same COM port.
Also make sure the datalogit is plugged in well to the PFC. Mine was tight and didn't want to fit well to start with. If your commander is working through the datalogit, or if the red light is on, on the datalogit box, you should be fine there.
I'm assuming you're using a regular serial port. If you're trying to use USB, that's a whole other can of worms...
Otherwise, you're right that you just need to click the "Read All" button to pull all the info from your PFC into the datalogit software.
Old Feb 16, 2005 | 09:36 PM
boost_guy's Avatar
thanks for the help guys I got it figured out. It was a bad connection between the commander and the datalogit
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ricardo.benin
Power FC Forum
Aug 24, 2015 04:16 PM
