Hi, I'm new user !!!!
Old Feb 15, 2005 | 05:13 AM
Jeff RX7's Avatar
Hello at all, I present myself: I have been Jeff, happy owner for 3 years of Mazda RX7 FD RZ of 1994, twin-turbo engine. I live in France and I try to too badly speak not English thus apologize me for the errors. here a photograph of my beautiful....
I don't know if I'm in the right post...???? I don't find where I have to go for a presentation....
need your assistance, today my RX7 does not function more correctly and nobody in France is able to find the breakdown. In fact, as soon as I full accelerate (WOT) the engine cuts off the supply (gasoline or lighting???). But the 4000 rpmit passes is good. By disconnecting the pipe of air inlet compressed Pb is not posed. I do not have a code error, the boost sensor is ok. Ultimately I cannot full accelerate before 4000 rpm, as soon as I exceed 0,2 bar there is a cut!!!!
What do you think about it ??????
Old Feb 15, 2005 | 09:04 AM
broken93's Avatar
apex seal BBQ
Jeff, welcome to the forum. You may want to read this thread for some background information:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Are you having a problem before or after 4000 RPM?
Old Feb 15, 2005 | 09:17 AM
alberto_mg's Avatar
also try the european section of this forum. i have seen various french speakers in there.
rotoboy661's Avatar
yes always look at the stickies 1st and search
welcome tho
im mike
Old Feb 15, 2005 | 09:27 AM
pugg57's Avatar
proper motoring
je ne parle pas français bien, satisfais ainsi me pardonne. vous dites que le problème se produit seulement avant 4000rpm ? est-il possible qu'une conduite à dépression se soit détachée ? aussi, vous avez un marché des accessoires ECU ou êtes lui des actions. nous dire quelles modifications vous avez effectuées sur la voiture nous aidera à vous aider.
Old Feb 15, 2005 | 09:33 AM
Jeff RX7's Avatar
thanks for your welcome.....
Troubleshooting are before 4000 RPM. I have checked all vacuum hoses and replace a lot of them with new ones.
I have installed on my car a new ported engine from hurley engeneering UK .... I've got a PF'S piggy back but I unplugged it. There is many performance parts but to foud the problem I configured my car in his stock version.... juste a blitz intake and HKS full exhaust.
It's souds like a ecu fuel cut but I'm not sure. Boost sensor is new, crank angle sensors too, 02 sensor too .... I don't know ????
Thanks for the european section....
Pugg57 your french is not so bad ....
Old Feb 15, 2005 | 09:36 AM
pugg57's Avatar
proper motoring
wow... are you sure? i just did a quick altavista translation of it and it made absolutely no sense at all
Old Feb 15, 2005 | 09:42 AM
pugg57's Avatar
proper motoring
alright, i'm not even going to attempt this is French...
you may want to reconnect the piggy-back ECU because the stock ECU may be having a problem controlling the fuel system with the ported engine. have you tried that yet?
Old Feb 16, 2005 | 03:52 AM
Jeff RX7's Avatar
I tried with and without the PF's pink piggy back = same problem.
It's like boost sensor detect too high boost pressure and ask ECU to cut off the ignition or fuel injection , BUT sensor boost is okay !!!
When I turn in atmospheric mode (without boost by disconnecting boost pipes before upper intake manifold) = no problem... acceleration is regular and there is no cut.
Old Feb 16, 2005 | 06:08 AM
pugg57's Avatar
proper motoring
do you have that issue at really low RPMs like... idle-2500 or is it just 2500-4000? is it possible that your primary wastegate is malfunctioning? at WOT maybe you are building too high of boost before the transition point so you are hitting fuel cut. after transition, the secondary wastegate could be compensating for the malfunctioning primary which would explain why you can go WOT after 4000rpm.
just a thought.
Old Feb 16, 2005 | 07:35 AM
Jeff RX7's Avatar
The problem appear when I fully accelerate (WOT) till the idle speed to 4000 RPM.
I must'nt press the accelerator over 3 PSI of boost. Since the engine is approximately 4000 RPM : I can WOT !!!
Old Feb 16, 2005 | 09:06 AM
pugg57's Avatar
proper motoring
well, i'm completely stumped... its always a possiblity that the ECU is just f*ed up... but i can't think of anything else. i'm very sorry and i hope you get it figured out soon.
