rear factory strut bar
Old Feb 13, 2005 | 01:55 AM
777fd's Avatar
does it make a difference in handling? i want to remove it for more hatch cargo room but was wondering if it makes a noticeable difference in stiffness.
Old Feb 13, 2005 | 02:41 AM
diablone's Avatar
If you wanted space, you should have bought a different car.
Old Feb 13, 2005 | 04:19 AM
RotorMotor's Avatar
DRIVE THE ROTARY SPORTS
agreed. its there for a reason... leave it
Old Feb 13, 2005 | 09:37 AM
adam c's Avatar
Cheap Bastard
Keep it. It stabilizes the whole rear end. Your car will feel much looser, and sloppy without it.
Old Feb 13, 2005 | 09:51 AM
JConn2299's Avatar
reliable performance
I remember reading a post years ago from someone who removed it (temporarily). He was going on a trip and needed more cargo room. He didn't say anything bad happened. I'm with the others though. I wouldn't mess with it. But that's me.
If you do decide to do it, come back and tell us what it was like and if anything bad happened.
Old Feb 13, 2005 | 09:52 AM
Section8's Avatar
If you've got the Bose Hose in the rear, I'd pull that out, that'll give you quite a bit more room.
Leave the rear strut bar, it's there for a reason.
Old Feb 13, 2005 | 11:32 AM
1QWIK7's Avatar
White chicks > *
im with the others, if they put a rear strut bar there from factory, it serves a purpose..
id leave it
Old Feb 13, 2005 | 01:21 PM
rynberg's Avatar
If you mean, can you remove it for a single trip that you need to haul more stuff, go for it. If you mean, can you remove it for long term use, buy a different car.
Old Feb 13, 2005 | 01:22 PM
ManGaZeRo's Avatar
Living the Dream
Anyone ever purchase an aftermarket rear strut bar and feel the difference?
Old Feb 13, 2005 | 04:28 PM
1QWIK7's Avatar
White chicks > *
^^i wanted to know the same thing, have you?
Old Feb 13, 2005 | 04:34 PM
jimlab's Avatar
Super Snuggles
Why would you feel a difference? The aftermarket strut bars I've seen are intended to accomodate eye bolts for harness mounts, which they're not much better for than the stock bar (because the flimsy mounting brackets are still a weak link). Side-to-side, however, there's no difference.
Old Feb 13, 2005 | 05:42 PM
Section8's Avatar
I would never trust my life with harnesses mounted to that bar, or an aftermarket piece there either.
