apexi avcr with non sequential turbos?
Old Feb 11, 2005 | 11:12 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Tried doing a search but came up negative. Anybody running their FULLY converted non sequential turbos with an apexi avcr boost controller? If so, what were your impressions and what must me done/hooked up differently to the turbos?? I have it hooked up to my stock sequential twins right now. Thanks a bunch.
Old Feb 12, 2005 | 01:25 PM
poss's Avatar
Slower Traffic Keep Right
How does it run? I'm not sure what you're looking for there. How about fine.
As far as hooking it up, run a vaccum line from a nipple on the primary snail to the NO port on the solenoid valve. Then from the COM port to the wastegate actuator. Plug the second nipple on the wastegate actuator.
Old Feb 12, 2005 | 01:30 PM
CANRX7GX's Avatar
PREDATOR
If I remember correctly, when I was looking into BOV's, the AVC-R is a good choice for non-sequential and the profecB spec 2 is good for sequential. As far as set-up goes... can't help you out much there as I am running a manual boost controller
CANRX7GX's Avatar
PREDATOR
I mean not BOV's... boost controllers
Old Feb 12, 2005 | 01:39 PM
RX7 RAGE's Avatar
Top Answer: 1
thanks..i'll look into it when i do the install
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
