Vacuum readings and what causes low vacuum
Old Feb 10, 2005 | 12:46 PM
newset7's Avatar
Newbie
what is a good vacuum reading at idle for a newly rebuilt engine and one that has 30k miles on it? I am showing 16 on the boost gauge and i have 400 miles on my rebuilt engine. i think this is kinda of low, any idea why it is so low?
Old Feb 10, 2005 | 01:04 PM
Fatman0203's Avatar
the seals probably have not worn in , at about 2000 miles is when the readings should get better. as it is 16 is pretty good, are you ported?
Old Feb 10, 2005 | 01:33 PM
soru81's Avatar
I have brand new engine with 1500 miles and my vacuum shows 16 @ 800 rpms. I'm waiting it picks up some more vacuum, too
Old Feb 10, 2005 | 02:30 PM
DaleClark's Avatar
RX-7 Bad Ass
16 sounds about right. Depending on how well built the motor is, if you went with used rotor housings, etc. will affect your final vacuum.
Many times budget rebuilt motors with used parts won't pull as much vacuum as a motor with new rotor housings, etc. They'll still run fine, but they'll just be a little looser. A street port will drop vacuum down a bit as well.
Dale
Old Feb 10, 2005 | 04:41 PM
spekdah's Avatar
mine says 20, is that good?
Old Feb 10, 2005 | 05:04 PM
Fatman0203's Avatar
Yea very.
Old Feb 10, 2005 | 07:20 PM
unixpilot's Avatar
Check out my Mooseknuckle
20 what? Kiwi's/km?
Old Feb 10, 2005 | 11:07 PM
16 to 18 is great... 20 is outstanding...... mine is 16 at idle and 20 TO 22 while coasting on the freeway at 65 MPH.
Old Feb 11, 2005 | 06:22 AM
WaLieN's Avatar
Call me gramps!
Yes, once you break your motor in, it should show better vaccum. Also, your idle rpm will also help determine your vaccum at idle. (high rpm == higher vaccum)
Old Feb 11, 2005 | 08:33 AM
alberto_mg's Avatar
At 800 rpm idle, i think you will find most turbo rotaries make around 16psi of vacuum. I have only seen one car pulling 20 psi of vacuum and that was my friend's low mileage 2 year old 89 Turbo II back in the day.
Old Feb 11, 2005 | 09:37 AM
Quickfini's Avatar
My car still seems to be pulling about 19-20 vacuum.. got about 91K kms..
Old Feb 11, 2005 | 10:11 AM
goldenchasers_101's Avatar
my vac. says 19. i went and had my oil changed and they knocked off the boostsensor vacuum line and it ran bout 10. I finally figured that was the problem so i hooked it back up and running 19 on vacuum.
Old Feb 11, 2005 | 03:26 PM
maxcooper's Avatar
WWFSMD
Variances in gauge accuracy, altitude, and engine RPM make large differences in vacuum measurements. If you are pulling 16, that's good. If you are pulling 20, I think your engine is probably healthy, but you may need an idle speed adjustment or a new gauge.
-Max
Old Feb 11, 2005 | 03:38 PM
Jayseven's Avatar
mine reads 16 at 900 rpms. I have a stock port reman with 3,000 miles on it.
thats why you change you own oil.
dkwasherexd
May 27, 2017 04:51 AM
Microtech
30
Apr 23, 2016 06:37 PM
20B Forum
Aug 30, 2015 12:08 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
