Which wheel is avail. in 17x9 & 9.5?
Old Feb 10, 2005 | 12:30 AM
Infini IV's Avatar
Microtech Tuning!
1) How much will a 17x9.5" (+5) wheel stick out past the stock (unrolled/unmodified) FC rear fender?
2) Are there any wheels available on the market today that come in 17x9 (+15) and 17x9.5 (+5)?
The only wheels I've seen that come close to that combo above is the Volk TE37. However, the 17x9.5 is only available in a +12 offset.
*I realize CCW may be able to build me wheels to my specs, but I'm curious to know if there are any wheels on the market that are readily available in those sizes I mentioned above.
Old Feb 10, 2005 | 04:35 PM
owen is fat's Avatar
I run a 17x9 5zigen FNO1Rc out back on my FC and the offset is +35, you can find pics thru the link in my sig. I run Tein Flex coilovers and have a good 1/2" to 3/4" clearance to the coilover perch and on the outside, the edge of the wheel is right to the egde of the unmodified fender lip.
If you run a 17x9 with +15 offset, that wheel will move outwards 20mm compared to mine and thats over 3/4" (20mm/25.4mm-per-inch = .7874inch)
now youre getting outside of the fender....
if you run a 17x9.5 with +5 offset, you place the edge of the wheel about 36mm farther outwards than on my 9" wheel is, that is 1.4" more outwards.
(.5"/2 = 6.35mm for the added width + the 30mm difference in offset)
I dont know which wheels come in those offsets without searching all over the net, but there are a load of wheels in 17x9 and some in 17x9.5 or 17x10 from 5zigen, volk, enkei, racing hart, ccw.
Old Feb 11, 2005 | 12:11 PM
this guy fits 275's out back using +25 offset and its right to the fender lip.
http://www.teamfc3s.org/forum/showth...ighlight=17x10
Old Feb 12, 2005 | 05:05 PM
Infini IV's Avatar
Microtech Tuning!
Yes, sorry I had forgot to mention that I had already figured out how far the wheels would protrude from the fenders.
I will be running +30mm wider front fenders and will be rolling/flaring the rear fenders out about 1". With a 17x9 +15, it should fit just perfectly inside of the front fenders. With a 17x9 +5, the outer rim of the wheel will sit right at the stock fender-lip, or less than 1/4" past it. But with my rear fender rolling/flaring, it should sit just perfectly within the fenders.
I also do not want to run larger than a 10" wide wheel out back because I want to keep the difference in the stagger setup as minimal as possible while running as wide a wheel as I can up front with sufficient clearance.
Old Feb 14, 2005 | 07:01 PM
Falcoms's Avatar
kill it with BOOMSTICK!
Looks nice, I like how the tires fill out the fenders as well as they do!
Old Feb 16, 2005 | 07:16 PM
Infini IV's Avatar
Microtech Tuning!
Bump
Old Feb 17, 2005 | 10:11 PM
Infini IV's Avatar
Microtech Tuning!
Also, how do I find the tire size that will provide the "squarest" profile in most tires? I was thinking a 255 width tire for the 9" and a 265 width tire for the 9.5" tire.
Old Feb 20, 2005 | 02:58 AM
Infini IV's Avatar
Microtech Tuning!
Bump
FB_Frank85
Sep 6, 2015 11:29 AM
