13BREW TPS into S4 ECU Q?
Old Feb 9, 2005 | 07:55 PM
IAN's Avatar
IAN
Rotary Reborn!
List,
I need some info on how to put a cosmo 13BRE(W) twin turbo motor TPS into a S4 ecu. Currently looks like the previous owner has jimmy rigged a stock TPS into the UIM and rigged it into the car. RIght now the car seems to be running really rich.
I have attached a poor picture of it. But if anyone has pictures or anything to share that would be great.
In fact a diagram of the twin turbo would help as well for wastegate boost control hookup.
Thanks,
Ian
Old Feb 9, 2005 | 08:49 PM
DaleClark's Avatar
RX-7 Bad Ass
The S4 ECU needs the VERY simple S4 TPS. It's basically a switch - tells the ECU when the throttle is closed, and when you're at about 20% throttle.
The FD and probably the Cosmo use a full-range TPS, which won't tell the ECU what it needs to know.
If you're running a Cosmo engine, the stock ECU has no business being in there. You need some sort of aftermarket fuel injection system - Microtech, Haltech, etc.
Dale
Old Feb 10, 2005 | 05:39 AM
IAN's Avatar
IAN
Rotary Reborn!
I understand the importance of a full standalone. That is out of the question due to cost. It is getting a Haltech F5.
Thanks for your help.
Ian
ZacMan
Sep 19, 2015 09:20 PM
