17x8 wheels on FC road race car
Old Feb 7, 2005 | 08:46 PM
jose-rs1's Avatar
Arrow 17x8 wheels on FC road race car
Any one running this wheels?
What should be the correct backspacing in front and rear?
Old Feb 7, 2005 | 09:51 PM
gnx7's Avatar
PM In2Twins (Carl Byck) for offset.
I bought his old ones from him 17x8 TSW's with 235/40/17 Toyo RA-1's. They fit perfectly with coilovers on the car (FC).
-Mark
Old Feb 8, 2005 | 08:33 PM
ShadowX's Avatar
You should be able to use stock offset without a problem....well, at least for the rear.
Old Feb 8, 2005 | 09:16 PM
Black91n/a's Avatar
I've got 17x8's 32mm offset on my street car with 225/45/17's and they fit perfectly withought rubbing, even at the track. You will be able to go with a bigger offset and wider tires with coilovers.
Old Feb 9, 2005 | 10:19 PM
Carl Byck's Avatar
Mad Man
Unfortunately I did not record the offset. Fortunately they were TSW Hokenheims, 17x8. I'm sure there is one fitment that is close, and that will be it(research). I used a sheet metal spacer in the front, as my car was extremely low. They worked very well, and were a good combo with the 235-40-17 RA1 Toyos. Coil overs w/2.5" spring are required. Carl
Old Feb 13, 2005 | 10:51 PM
jose-rs1's Avatar
will you consider putting these wheels?
do you think they will take the abuse? load rating 2,200 lbs
cragar 17 x 8 steel. only 53 bucks
http://store.summitracing.com/default.asp
Ntt=cragar+397&Ntk=KeywordSearch&DDS=1&searchinres ults=false&N=0&target=egnsearch.asp
Old Feb 13, 2005 | 11:26 PM
jose-rs1's Avatar
sorry the link did not work
part summit part # crr3978812
Old Feb 14, 2005 | 03:49 PM
jose-rs1's Avatar
just called cragar they weight 38 pounds. so forget about them.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
4sfeedit
Aug 16, 2015 01:42 PM
