Power FC Would the power fc be a good choice with moderately modded FD?
Old Feb 7, 2005 | 07:14 PM
steve0178's Avatar
rx7 enthusiast
I am in the market for engine management and i was wondering just how good the fc is. Most of the posts i have read about the fc talk about lightly modded cars. I was wondering if it would be a good match for what i am looking to do.
So far i have intake, dp, mp, exhaust, stage 3 port, 3mm apex seals, fuel pump, and within the next couple of months i plan to go with a single turbo upgrade and run about 15-20 psi. Would the fc be a good match for those mods or would it be a better choice to go with a microtech or haltech?
Also what other random parts would i need to get it running correctly. For example, would i need a wideband 02 sensor/monitor? would i need a 3 bar sensor? I am new to engine management so please excuse me if i am asking stupid questions.
Old Feb 7, 2005 | 08:02 PM
jeremyb's Avatar
Hi....
Yes a powerFC would fit you perfectly. You don't have to be just "lightly modded" to use it though. You can run a bridgeport with a T-88 turbo, etc. and still be able to use the PFC. Those that use haltech, microtech, and AEM use them due to the higher "cell by cell" tuning. A PFC would be what you should go for if you were looking towards a stand-alone ecu. If you are tuning the car yourself, you would need a wideband 02 and datalogit. But if you were just buying it and having someone tune it, majority shops that tune PFC's will have a datalogit and wideband 02. I have the PFC myself and the commander to moniter its settings, wtr temp, inj. duty cycle, timing, boost, etc. A commander is just an option. I bought it because I wanted to be able to do a little fixing here and there myself and other things .
Jeremy
Old Feb 7, 2005 | 09:19 PM
Tim Benton's Avatar
FD title holder since 94
I'd take a PFC with the datalogit set up any day over the microtech setup. It will be fine for your plans in the future.
Tim
Old Feb 7, 2005 | 10:44 PM
jpandes's Avatar
I went for the full-boat: PFC, Commander, Datalogit & TechEdge WB20 w/ display. The Datalogit and the Tech Edge cost me $700. I can now tune my car whenever I make a change to my set-up. It helps to have someone local to show you the ropes of tuning your AFR's...
Old Feb 8, 2005 | 01:05 PM
luizajeff's Avatar
Questing though, with all those mods you have now, are you still on stock ECU? If so you might be ready for a new motor too. (Unless you have your ecu chipped for now) But yes, the PFC is very expandable and is the reason so many get it.
Old Feb 9, 2005 | 02:51 PM
steve0178's Avatar
rx7 enthusiast
Well actually it is in the middle of a rebuild so the car has never been run on the stock ecu with those upgrades. A lot of the items i have were just added on during the rebuild. Before it was just bolt ons...The previous motor was running a safc2 by the previous owner.
Thanks a lot for all your help
ChrisRX8PR
Aug 21, 2015 01:56 PM
