Is it safe to...
Old Dec 16, 2001 | 04:15 PM
MILD7's Avatar
Is it safe to...
Stupid question: Is is safe to add water (room temperature) to the filler neck while the car is fully warmed up? I'm not concerned about getting burned my coolant, but rather warping the housing due to change in temperature. Should I let the car cool down first? Thanks in advance.
Old Dec 16, 2001 | 05:54 PM
RTS3GEN's Avatar
The Man
as long as there is water already in the engine it won't hurt anything, but if you're that concerned you can just fill the overflow tank to full with the water and leave the fill cap on the pump neck and the water will get pulled into the system as needed.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
NickNac113
13
Oct 1, 2015 09:25 PM
rotor_veux
Sep 28, 2015 09:25 PM
