Power FC Plumbing Power FC and AVC-R
Old Jan 25, 2005 | 04:26 PM
Welsh Dan's Avatar
Hi.
We're just finishing converting my FD over to non-sequential turbos, and i'm going to be using the AVC-R to control the boost.
I'm not too concerned about wiring and plumbing the AVC-R in, but I need to know if I would keep the standard MAP sensor in place for the Power FC to use and plumb in the 3 bar map sensor for the AVC-R. I know how to set the power FC so that it doesn't interfere with the AVC-R, but its just whether I should have one sensor or both sensors that is confusing me?
Old Jan 27, 2005 | 01:09 PM
aspinall's Avatar
Newbie
Smile
jus over here havin a nose around as usall.seen ur post on mrc 2.
u sorted it out yet,im asp buy the way
Old Jan 28, 2005 | 08:22 AM
drc's Avatar
drc
I think I know what your asking, you want to know if you can use the same sensor that comes with the AVCR for both the powerfc and the avcr?
Use the sensor that came with the AVCR only for the avcr, leave the stock sensor alone/connected to the PFC. If you want a 3 bar for the powefc, I think there is a GM sensor you can use or the powerfc sensor from rx7.com.
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
