MY Exhuast idea....
Old Jan 24, 2005 | 07:03 PM
Modified 7's Avatar
MY Exhuast idea....
well i have the rb header and presilecer with stock piping with rb mufflers...if i get the piping custom..into a y pipe...maybe like 2 in a quarter inch how much h.p. do you think i could get? Thats just with the piping...thats all i need to make a full exhaust...
Old Jan 25, 2005 | 09:37 AM
MPM's Avatar
MPM
IF you mean your increasing the pipe after the y-pipe to 2 1/4" back to the mufflers then no, you won't gain any HP. Unless your engine is ported pretty good then you might gain a few. Stick with 2" after the Y and match it the the outlet of the presilencer which I believe is 2.5". Or you could by the Racing Beat Y-pipe since everything else is already RB.
Old Jan 25, 2005 | 11:23 AM
Modified 7's Avatar
why would i by the rb y pipe id i get no h.p?
Old Jan 25, 2005 | 11:51 AM
rxtasy3's Avatar
the exhaust tubing used should match the size used in the header if ur going with the long primary system. otherwise, from header to single pipe, it's whatever the math is to figure the I.D. for the tubing after the header. i think the header is 2" I.D. so that into a single pipe to yield the same volume would probably be no larger than 2.5" I.D.
Old Jan 25, 2005 | 10:42 PM
Modified 7's Avatar
so from the presilencer make the piping 2.5" for positive power gains?
Scott 89t2
20
Oct 6, 2002 01:32 PM
Net Seven
May 17, 2002 07:33 PM
