Air and fule ratios too lean
Old Dec 14, 2001 | 03:42 PM
SiyahGTU's Avatar
I just bought a TII with bonez mid and down pipe and some kind of cold air induction. There are no fuel mods to the car. I am wthinking that it is running lean and could use more fuel. As far as I understand it "fuel cut defensers" only fool the computer againts shutting off fuel supply.
A high output fuel pump sounds to be a better idea. Is there a specific output that I need to look for in this setup of exhaust and intake?
Any help would be appreciated
Old Dec 14, 2001 | 05:09 PM
mazdaspeed7's Avatar
mad scientist
Go for a Walbro pump. I think www.summitracing.com has them for a reasonable price. You probably should also get an adjustable fuel pressure regulator so you can raise the fuel pressure if necessary.
Old Dec 14, 2001 | 07:57 PM
Jerk_Racer's Avatar
Make sure your fuel pump is getting the correct voltage. If it's not, it might cause a run lean situation. If it is getting the right amount of voltage, then think about spending some money to fix this problem. Do a search for it and you'll find instructions for it. Good luck.
jerk_racer@hotmail.com
20B Forum
21
Mar 22, 2022 01:00 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Microtech
Nov 21, 2015 10:20 AM
ZacMan
Sep 19, 2015 09:20 PM
