18X8.5 and 18X9.5 Offset 35 on FD
Old Jan 21, 2005 | 08:35 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
I have a set of Stern ST7 Wheels that i bought from ebay.
these are 18X8.5 front with a 35 offset and 235 40 18 tires
rear is 18X9.5 with 35 offset and 265 35 18,
is it okay? will it fit good?
Max
Old Jan 21, 2005 | 08:37 PM
apex_sideway's Avatar
FD dream is dead
Won't fit. Backs maybe. Wait for SpeedKing or someone else to verify.
Old Jan 21, 2005 | 08:41 PM
SpeedKing's Avatar
Power Trippin'
Yep, yep. Wheels no workie.
Old Jan 21, 2005 | 09:35 PM
rynberg's Avatar
hmm...perhaps you should have asked BEFORE buying them? No, they will not fit.
Old Jan 21, 2005 | 09:46 PM
Old Jan 21, 2005 | 09:59 PM
there's no way it can be fit??
Old Jan 21, 2005 | 10:03 PM
rynberg's Avatar
The rears may fit by rolling the fenders, the fronts may still rub even with rolled fenders. So, no, they do not fit.
Old Jan 21, 2005 | 10:06 PM
FD dream is dead
Time to look into some fender flares budddddieeee
Old Jan 21, 2005 | 10:31 PM
Old Jan 21, 2005 | 10:38 PM
FD dream is dead
Old Jan 21, 2005 | 11:36 PM
gambit023's Avatar
check out this post near the bottom. Red FD. https://www.rx7club.com/suspension-wheels-tires-brakes-20/will-i-rub-18x8-5-rims-245-40-18-tires-386099/
it will fit.
Old Jan 22, 2005 | 12:03 AM
rynberg's Avatar
Originally Posted by gambit023
check out this post near the bottom. Red FD. https://www.rx7club.com/showthread.php?t=386099
it will fit.
No they will not. Rubbing at full turning lock (with little load on the suspension) is NOT fitting!
Old Jan 22, 2005 | 12:40 AM
it should look nice if you roll the front and drop it, if thats any consolation. a little rubbing shouldnt make you wet your pants anyways...probably is a good idea to ask before you buy though, hope you got a good deal!
Old Jan 22, 2005 | 01:58 AM
SpeedKing's Avatar
Power Trippin'
Yes. And keep in mind that every car is different and has its own suspension and tire setup.
"gambit023": Why don't you mention what springs/shocks you're running? It would a great reference point. What consolation would you have for someone that believes what you post, then proceeds to go and pull his fenders out?
Old Jan 22, 2005 | 09:27 AM
i have koni yellow and eibach springs
Old Jan 22, 2005 | 01:58 PM
FD dream is dead
I belive with the Eibach's you should have some rubbing issues; the spring rate in front isn't stiff enough. I haven't seen it personally but that's what everyone says. Rolled fenders and coilovers seem to be the answer. Good luck and i hope you find a solution.
Old Jan 22, 2005 | 02:36 PM
thanks guys, Btw it is not for me, but for my dad, he bought these wheels on ebay and he thought it would fit. But, we'll make them fit
anyway, thanks a lot for your help.
Max
Old Jan 22, 2005 | 04:44 PM
gambit023's Avatar
Ok ... here are the details.
SUSPENSION:
Stock Shocks
Racing Beat Springs in the Front
H&R Sport Drops in the Rear (Don't ask me why)
WHEELS:
ADR M-Sport
18*8.5 Front +35 Offset
18*9.5 Rear +35 Offset
TIRES:
245/40/18 Front
265/35/18 Rear
Fenders were rolled with a baseball bat and heat gun. Rubbing? Yes. On full turns (e.g. tight parking lot turns) Rubbing while normal driving? No. Rubbing when hitting a pothole the size of someone's fat head: Yes
Old Jan 22, 2005 | 06:31 PM
1QWIK7's Avatar
White chicks > *
^^nice man, do you have any side shots or angled shots of your car.. i really like those rims..
Old Jan 22, 2005 | 10:51 PM
rynberg's Avatar
Great recommendation! Rubbing on tight turns should be considered unacceptable! Why would you make such a rediculous sacrifice just to fit some heavy, poorly made wheels?
Old Jan 22, 2005 | 11:04 PM
ARD T2's Avatar
lolzzzz. You tell em Ryn. I concur.
Old Jan 23, 2005 | 01:41 AM
SpeedKing's Avatar
Power Trippin'
That way is the bullshit way. Do it right - get wheels in the correct sizes w/ the proper offsets - no rubbing, no problems.
Old Jan 23, 2005 | 04:16 PM
gambit023's Avatar
Let me clear things up here. You guys are bitching and moaning because of the rubbing. Well the rubbing occurs on the inner fender liner front on full turns. If you get a higher offset, which SpeedKing, ARD T2, and rynberg are indirectly suggesting, this will push the wheel further into the car. Thus, causing even more rubbing. So, take their advice and see what happens. I’m not saying that the +35 offset is the best in the word. But it works.
SpeedKing, ARD T2, and rynberg, you ******* need to pull the ****** out of your asses and move on in life. You **** little bitches.
Old Jan 23, 2005 | 07:20 PM
tigerdriver's Avatar
Evader of Legal Issues
Exclamation
Sounds like someone might have some attachment issues...
Old Jan 23, 2005 | 07:42 PM
FD dream is dead
Nice, lets dis some of the most helpful members on this forum about something they know about.
