Tire Help
Old Jan 19, 2005 | 02:07 PM
djseven's Avatar
Eh
Tire Help
Hey guys I did some searching and couldnt exactly get the info I was looking for. I just bought a set of the 99 spec wheels and I am wanting to buy some tires now. I was wanting to run 235/45/17 in front and wondering what I should run in the rear to give the car an aggressive look. I am usually pretty good about finding info for myself but when it comes to tires and suspension I have no clue. If anyone has pics of their car with 235/45/17 and 255/45/17 in the rear I would love to see the pics and also know what suspension setup you are running also.. Thanks for the help in advance.
David Jerome
Old Jan 19, 2005 | 05:53 PM
macdaddy's Avatar
Our cousins at miata.net have a neat tire size calculator that you can use to compare various tires to the OEM size. http://www.miata.net/garage/tirecalc.html
Combine that with the info from tirerack.com, and you should be able to figure out what makes sense for you. I'm running 245/40-17's all around - next time I'll go to 255/40-17's. That's on 9" wide rims, using coilovers with 2.5" springs - don't know the 99 spec wheel width off the top of my head, but tire rack will give you ideal and acceptable wheel widths for any size tire they have.
rx7jocke
72
Jun 17, 2016 03:48 AM
