Power FC Is it safe to buy a used power fc?
Old Jan 18, 2005 | 02:20 PM
jayk's Avatar
Is it safe to buy a used (tuned) power fc? I'm really just looking for the base maps for an intake, downpipe, and exhaust, nothing fancy. Is it possible to reset the power fc to default (base) settings or is the base map lost once it has been tuned?
Old Jan 19, 2005 | 01:58 AM
rotoboy661's Avatar
bought mine used
just gotta be weary tho
yes u can reset them
i might have one 4sale
mike
Old Jan 19, 2005 | 10:13 AM
books's Avatar
I bought one used and have used it on 2 different cars. I do have a wideband though to track AFRs. You can reset the PFC and it will revert to the original maps installed, either the base maps or base mod maps. There are some negative splits you need to correct. I noticed on one vehicle when the maps were reset that the AFRs were very safe under boost. The PFC seems to model Mazda target values.
Old Jan 19, 2005 | 10:19 AM
Rx-7Addict's Avatar
Rotary Powered
I bought mine on ebay from Japan and it works just as well as a new PFC.
Just make sure you look to see that the ECU is a 11/91-12/95 or whatever. Make sure it is the right ECU for the model year, Mazda changed ECUs later on, but all US FDs use the older style ECU.
Jun 26, 2016 10:21 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
cam_7779
Aug 18, 2015 07:48 AM
