Microtech elec fan diagram...will this work?
Old Jan 12, 2005 | 12:06 PM
turbo80cid's Avatar
elec fan diagram...will tis work?
I want to use the stock elec. fan along with my belt driven fan. I found this in an old post but I changed a bit.
Thanks
Old Jan 12, 2005 | 03:15 PM
Aaron Cake's Avatar
Engine, Not Motor
For some reason I am having a major problem understanding that because it's not a real schematic...But...
Fundamentally it is correct.
I would recommend that instead of directly switching the relay with your manual switch, put another relay in parallel and switch it. I just don't know if the effect of switching the Microtech's output directly to ground would be a good thing.
Old Jan 12, 2005 | 03:55 PM
turbo80cid's Avatar
what if I remove the switch, would that be better?
I don't need the switch just thought it would be nice to have.
Old Jan 12, 2005 | 11:34 PM
NZConvertible's Avatar
I'm a boost creep...
I see you've been messing with my diagram...
I originally had a temp switch in there that provided a switched ground to pin 86. Since the MicroTech aux output does the same thing it will work fine. The switch should not affect the MicroTech at all since it's basically just two switched grounds in parallel.
Old Jan 13, 2005 | 06:28 AM
turbo80cid's Avatar
ya thanks for the diagram.
So this won't have any ill effects on the Microtech?
The last thing I want to do is burn up my Mircotech because I wired something wrong.
Thanks
Old Jan 14, 2005 | 08:16 AM
remtec76's Avatar
Rotor Head
are you trying to turn it on with the microtech and the switch?
Old Jan 14, 2005 | 09:39 AM
turbo80cid's Avatar
the switch is pointless but I thought it would be nice to be able to turn the fan on when I want to.
Old Jan 14, 2005 | 12:56 PM
surfpac's Avatar
That will work fine.
Old Jan 15, 2005 | 07:11 PM
I would've though the MicroTech manual would have instrctions for wiring an e-fan in, since that's the sort of thing the aux output is for. Do whatever they say, which will be similar anyway.
Old Jan 16, 2005 | 08:30 AM
turbo80cid's Avatar
the manual doesn't say much about installing a fan.
I wired it all up yesterday and it works great.
Thanks again
Old Jan 17, 2005 | 10:43 PM
patman's Avatar
Resident Know-it-All
why do that? the stock fan is mostly not part of the engine wiring harness, and comes on at 207* F with its own thermoswitch.
Old Jan 17, 2005 | 11:12 PM
Evil Aviator's Avatar
Rotorhead
Does the Microtech operate the fan when the ignition is off? If not, then you may want to use a separate thermo switch instead of the Microtech. Part of the reason why the electric fan is so great is because it can operate with the engine off. The mechanical water pump isn't circulating the coolant when the engine isn't running, but the fan can still cool down the system some.
BTW, I merged the two threads.
Old Jan 18, 2005 | 08:08 AM
patman's Avatar
no, microtech does not function at all with the ignition offf if wired correctly.
Old May 9, 2005 | 05:01 PM
Sir Rupert Hobo's Avatar
seven-less
sorry for the bump...
but i would think the above would be a good reason to get a turbo timer. esp. if your have an oil cooled, only, turbo at the same time.
streetlegal?
Mar 17, 2022 02:46 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
